Thread Closed
Extra dimensions vs. dark matter in the LHC
Share Thread Thread Tools
Jun21-09, 08:21 AM   #1
It is my understanding that physicists hope to use conservation of energy in the LHC to determine if there are multiple dimensions AND if there is dark matter. Let's suppose that through conservation of momentum, we detect a particle that apparently only reacts through gravity, and there is some amount of energy lost. Would we just E=mc˛ to determine how massive the particle is? What if more energy is lost via extra dimensions?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jun21-09, 11:33 AM   #2
Quote by kashiark View Post
The missing energy is just one "dimension" to the problem. In practice, you need many more (generalized) "coordinates". Different physics will show different behaviors in the interplay (correlations) between those coordinates, which has to be studied by simulation but is not necessarily model-dependent(*). In the literature, this us called "signature" for dark-matter for instance.
(*) For instance, you have a model predicting the existence of a spin 1/2 particle. Given the assumptions of this model, you calculate a cross-section. The angular decay in the rest-frame of your model-dependent particle is itself model-independent (or better, depends not on the assumptions of your own model, but only on Lorentz invariance)
Jun21-09, 11:51 AM   #3
So with all of that other information they can determine how much of the missing energy is actually the mass of the particle?
Jun21-09, 11:56 AM   #4
Depending on which reaction exactly, it may or may not be done on an event-by-event basis. But given the entire sample, using statistical analysis, yes. You may want to read about "Dalitz plots" for instance. Note that, otherwise (if they could not determine the mass of the missing particle), they would simply not understand anything !
Jun21-09, 12:00 PM   #5
Huh, thanks! That's been bothering me for weeks.
Jun21-09, 12:46 PM   #6
Also, note a very general thing : IF you manage to find an example where even in principle you can NOT distinguish between the two final states (say missing particle VS extra-dimension), THEN the two processes interfere (you can not add cross-sections, you must add the amplitudes). Typically, the production of your particle would be enhanced in some kinematical regions and suppressed somewhere else, due to extra-dimensions. Now in this case, it's not so trivial to make general statements. But you can already imagine that the dependencies become more complicated, say richer, and it's not impossible that you get a better handle on your parameters. But I expect that proponents of extra-dimensions would in any case like to cross check the results using another channel without this specific particle.
Thread Closed
Tags
conservation, dark matter, energy, lhc
Thread Tools
Similar Threads for: Extra dimensions vs. dark matter in the LHC
Thread Forum Replies
Extra dimensions don't go with dark energy (new Steinhardt no-go theorems) Beyond the Standard Model 22
Dark matter highlights extra dimensions General Astronomy 38
Observational Evidence for Extra Dimensions from Dark Matter Beyond the Standard Model 1
dark matter doesn't (or what's the matter with dark matter? or pick your lame pun) General Physics 4
Eureka! I think. (A layman's explanation of extra dimensions, dark Beyond the Standard Model 1
