Thread Closed
Uniform Charge, Electric Field
Share Thread Thread Tools
Jun21-09, 06:52 PM   #1
A very long uniform line of charge has charge per unit length 5.38 micro coulombs /m and lies along the x-axis. A second long uniform line of charge has charge per unit length -3.66 micro coulombs /m and is parallel to the x-axis at y = 0.400m. What is the net magnitude of the electric field at the point y = 0.200m? Give your answer in N/C in scientific notation to three significant digits.
2. Relevant equations
E=1/2pi(Epsilon)*[Uniform Charge length/R^2]
3. The attempt at a solution
I tried summing the two electric fields by using the above equation for each uniform charge and adding them together, however the answer is wrong. I also used 1/4pi(epsilon) but it was still wrong, what am i missing?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jun21-09, 06:56 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by Digdug12 View Post
Keep i mind that the E-field is a vector field.
Add like a vector instead of just summing, because direction matters.
In this case since they are opposite signs, and your point is in the middle, your answer should be ...
|E| = |E1| + |E2|
Thread Closed
Thread Tools
Similar Threads for: Uniform Charge, Electric Field
Thread Forum Replies
charge enclosed in uniform electric field Introductory Physics Homework 1
Electric field caused by a uniform linear charge Introductory Physics Homework 1
Uniform charge Electric field Introductory Physics Homework 5
The Electric Field of a Ball of Uniform Charge Density Advanced Physics Homework 5
Electric charge and fields: uniform electric field Introductory Physics Homework 1
