Speed & Force in Toy Car on Frictionless Ramp
  • Context: Undergrad
  • Thread starter Thread starter StephenPrivitera
    Energy
The discussion revolves around a physics problem involving a toy car rolling down a frictionless ramp and navigating a circular loop. Participants explore various methods to determine the car's speed at different points, the forces acting on it, and the minimum height required for the car to complete the loop without falling off. The scope includes energy conservation principles and forces acting on the car.
  • One participant outlines the energy conservation approach to find the car's speed at the bottom and top of the loop, suggesting equations based on initial and final energy states.
  • Another participant proposes a method involving forces acting on the car, including gravitational force and centrifugal force, to derive the minimum height H required for the car to complete the loop.
  • A later reply questions the use of centrifugal force in the analysis, suggesting that the problem should be approached using energy conservation principles instead.
  • Another participant introduces the variational principle and Lagrange multiplier method as alternative techniques to solve the problem, although this is met with confusion from others who are unfamiliar with these concepts.
  • One participant expresses uncertainty about the problem's requirements and seeks clarification on the correct approach, indicating a lack of familiarity with some concepts discussed.
Participants express differing views on the appropriate methods to solve the problem, with some advocating for energy conservation while others introduce force-based approaches. There is no consensus on the best method or the correctness of the proposed solutions.
Some participants highlight limitations in their understanding of centrifugal force and energy conservation, indicating that the discussion may depend on specific definitions and assumptions not fully articulated in the thread.
Readers interested in classical mechanics, particularly those exploring energy conservation and forces in circular motion, may find the discussion relevant.
StephenPrivitera
A toy car of mass M rolls down a frictionless ramp of height H > 2R and makes a circular loop of radius R at the bottom. (a) What is the car's speed at the bottom of the loop (b) at the top of the loop? (c) What is the force exerted by the track at the top of the loop? (d) What is the minimum value of H such that the car goes around the loop without falling off due to gravity?
The first two parts are simple.
a) Ei = MgH = Ef = 1/2Mv^2 solve for v
b) Ef = 1/2Mv^2 + 2MgR = Ei solve for v
But then...
c) The best I can do for this is figure that the track should exert a force downward on the car at the top of the track. So the forces acting on the car are Fnet = mg + Ft = ma, where Ft is the force exerted by the track. If I could find a, I could find Ft. But I can't do either.
I haven't even tried part d yet.
Help, anyone?
Hi!
Minimum H can be calculated by:
MgH=1/2Mv^2+2MgR (1).
Forces which is exerted on the car are -Mg, centrifugal force=MR&omega^2 and the force, T, which the surface of the track exerts on the car. Here, R&omega=v(speed of the car in the loop). So,
0<T=MR&omega^2-Mg=Mv^2/R-Mg (2).
Equation (2) means the car is attached on the surface of the track, i.e., the car exerts the force on the surface of the track, then .an opposite force is exerted on the car.
Simultaneously solving the equation (1) and (2), we have:
H>5/2R.
If there is any mistake, please correct, anyone!
Please refer to the book of classical mechanics to be sure that the expression for the centrifugal force here is correct.
I haven't learned about the centrifugal force. The chapter is on energy conservation, so I assume the problem is supposed to be solved using those laws.
I do not know how the problem is solved only by energy conservation law. Did you learn about variational principle? If so, you must know Lagrange multiplier method. Using this technique, you can get the same result.
Nope. I've never heard of any of these. The question comes from volume 1, chapter 7, question# 36 in "Physics for Scientists and Engineers" by Fishbane et al. I guess I'll try not to let it keep me awake at night, but it would be nice to see a solution.
30K
13K
18K
