Thread Closed
Series Wiring Problem
Share Thread Thread Tools
Jun22-09, 07:21 PM   #1
Two resistances R1 and R2, are connected in a series across a 12-V battery. The current increases by .20 A when R2 is removed, leaving R1 connected across the battery. However the current increases by just .10 A when R1 is removed, leaving R2 connected across the battery. Find(a)R1 and (b) R2.
V=12v
2. Relevant equations
R1+R2=Rs V1+V2=V
I=V/R
3. The attempt at a solution
I+20= V/R1 I+10= V/R2
I believe the two equations above would give me my answers but I'm stumped on how to go about finding the unknowns. I know V=12 but I can't figure out how find the current or resistances.
Can somebody point me in the right direction?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jun22-09, 08:02 PM   #2
Recognitions:
Homework Helper Homework Help
Looks like you need 3 equations for the 3 unknowns.
V = I*R looks like it yields all 3.
(R1 + R2) = V/I
R1 = V/(I + .1)
R2 = V/(I + .2)
Then solve right?
Jun23-09, 02:21 PM   #3
Using the three equations makes sense, but I can't figure out how to find the unknowns. All I know is V, and I need to know I to be able able to find R1 and R2.
my idea was to subsitute I=V/R into the equations and then try to solve for R1 and R2.
so R1= V/(V/Rs)+.1
but I don't know what Rs is either.
Jun23-09, 02:35 PM   #4
Recognitions:
Quote by runfast220 View Post
so R1= V/(V/Rs)+.1
Don't use Rs as that is by definition R1 + R2.
Otherwise, if you must, then you have 4 equations, with the 4th unknown now Rs where Rs = R1 + R2
Jun23-09, 03:00 PM   #5
ok but if I plug R1 + R2 into the equation I still have too many unknowns.
R1=V/(V/R1 + R2) +.1
In that equation I still don't know how to find R1 or R2.
Jun23-09, 03:17 PM   #6
Recognitions:
Disregard; I misread the problem question.
Jun23-09, 03:17 PM   #7
Recognitions:
You only have 3 unknowns : I, R1, R2, because V is 12.
(R1 + R2) = V/I
R1 = V/(I + .1)
R2 = V/(I + .2)
Rewriting you have
12 = I*R1 + .1R1
12 = I*R2 + .2R2
12 = I*R1 + I*R2
Adding equation 1 to equation 2 and subtracting equation 3 yields
12 = .1R1 + .2R2 or, ...
120 = R1 + 2R2
Surely it's down hill from there.
Jun23-09, 05:28 PM   #8
Here is my attempt at the solution:
(R1 + R2) = V/I R1 = V/(I + .1) R2 = V/(I + .2)
SO:
(V/(I+.1)) + (V/(I+.2))=V/I
(12/(I+.1)) + (12/(I+.2))= 12/I
24I^2 + 3.6I = 12I^2 + 3.6I +.24
12I^2 = .24
I=.02 A
R1 = V/(I+.1) = 12/(.02+.1) = 100 OHMS
R2 = V/(I+.2) = 12/(.02+.2) = 54.5 OHMS
Jun23-09, 05:50 PM   #9
Recognitions:
here is my attempt at the solution:
(r1 + r2) = v/i r1 = v/(i + .1) r2 = v/(i + .2)
so:
(v/(i+.1)) + (v/(i+.2))=v/i
(12/(i+.1)) + (12/(i+.2))= 12/i
24i^2 + 3.6i = 12i^2 + 3.6i +.24
12i^2 = .24
i=.02 a
i = (√2)/10
Jun23-09, 07:03 PM   #10
I = .14 A
R1 = 50 ohms R2 = 35.3 ohms
Thank you for all your help.
Thread Closed
Thread Tools
Similar Threads for: Series Wiring Problem
Thread Forum Replies
correct series-or-parallel-or-off switch wiring? Electrical Engineering 6
wiring speakers Electrical Engineering 9
Series wiring problem Introductory Physics Homework 2
