Maxwell's Demon: Chance of Violating the 2nd Law?
The discussion revolves around Maxwell's Demon and the implications for the second law of thermodynamics. Participants explore hypothetical scenarios regarding the demon's ability to separate gas molecules without acquiring information, as well as the feasibility of using an atom diode for similar purposes. The conversation touches on concepts of entropy, probability, and the nature of thermodynamic laws.
  • Some participants propose that if the demon operates without acquiring information, it might still achieve separation of molecules purely by chance, potentially violating the second law.
  • Others argue that the probability of such an event occurring is extremely low and can be regarded as zero, especially as the number of particles increases.
  • A participant mentions that while the second law suggests entropy tends to increase, deviations from this can occur but are less likely with larger systems.
  • There is a suggestion that an atom diode could separate atoms based on their direction of motion, although this is contested by others who state that it requires work, similar to other methods.
  • Some participants discuss the implications of molecular motion and how it could influence the effectiveness of the demon or the atom diode in separating molecules.
Participants express differing views on the likelihood of violating the second law through chance events. While some acknowledge the theoretical possibility, others emphasize the practical improbability, leading to an unresolved debate on the topic.
Limitations include assumptions about the behavior of particles in small systems versus large systems, as well as the dependence on the definitions of information and work in thermodynamic contexts.
wendten
http://en.wikipedia.org/wiki/Maxwell%27s_demon"
Maxwell imagines one container divided into two parts, A and B. Both parts are filled with the same gas at equal temperatures and placed next to each other. Observing the molecules on both sides, an imaginary demon guards a trapdoor between the two parts. When a faster-than-average molecule from A flies towards the trapdoor, the demon opens it, and the molecule will fly from A to B. The average speed of the molecules in B will have increased while in A they will have slowed down on average. Since average molecular speed corresponds to temperature, the temperature decreases in A and increases in B, contrary to the second law of thermodynamics
Szilárd pointed out that a real-life Maxwell's demon would need to have some means of measuring molecular speed, and that the act of acquiring information would require an expenditure of energy. The second law states that the total entropy of an isolated system must increase..
when i read this i was wondering, what if the deamon accuires no information at all and just shoots blind by guessing wherever a approaching particle is A or B..
in most cases the demon would end up with a no separation, but if its lucky enough it might separate them entirely and violate the second law
... just a thought ;-)
The molecules might also divide spontaneously, if "you're lucky enough". The chance of that happening (and the chance of your demon 'accidentally' separating the molecules) are simply so small that they can be regarded as zero.
which means that the change of the law being violated is regarded as zero, but not that it is zero?
and if the amount of particles in the containers is just small enough there actually is a good change that a sepperation might be the case
The Second Law tells us that total entropy tends to increase to a maximum, and that significant deviations become less and less likely as a system's size increases.
In your gas chamber example, for example, no physical law says that exactly 50% of the atoms must be on each side. But 50% becomes a better and better approximation as the number of atoms increases. (I believe the deviation goes something like [itex]N^{-1/2}[/itex] for N particles.)
an atom diode would work just as well. it can't separate slow moving from fast moving atoms but it can separate atoms moving one direction from atoms moving the opposite direction
The font springs eternal.
One cannot violate the laws of thermodynamics with an atom diode. It takes work to use an atom diode to move atoms from the left half of a box to the right half, just as it takes work to accomplish the same thing with a piston.
the idea is that the motion of the molecules due to heat would move them through the barrier in one direction and once through would be trapped on the other side
You can't create a perpetual motion machine that way.
  • · Replies 28 ·
  • · Replies 17 ·
