| Thread Closed |
Momentum and Kinetic Energy Equation for Elastic Collisions |
Share Thread |
| Jun24-09, 07:00 PM | #1 |
ok so, i have an assignment due tomorrow, i know, late starting, but i can't figure out how to rearange the kinetic energy and momentum equation to get the v1f and v2f
i know that you have to find one term in the for of the other, but i dont know how to rearange my equation so that i have that... the equation is: 1/2 m1v1o^2 + 1/2 m2v2o^2 = 1/2 m1v1f^2 + 1/2 m2v2f^2 i dont know if you have to take the 1/2's from the right and multiply the LHS by 2, or if you have to take one of the 1/2mv^2 to the other side before doing that. |
| Jun24-09, 07:23 PM | #2 |
Mentor
Hi AussieBec,
Welcome to PF! Remember that you can do any (mathematically allowable) thing to an equation so long as you do it to both sides of the equation (that way you ensure that the equality still holds true). In this case, since every single term is multiplied by 1/2, it seems like multiplying both sides of the equation by 2 would be a useful thing to do (because doing so would get rid of all of the factors of 1/2). |
| Jun24-09, 07:29 PM | #3 |
:D thank you.
ok so now i have 2(1/2 m1v1o^2 + 1/2 m2v2o^2) = 2(1/2 m1v1f^2 + 1/2 m2v2f^2) which simplifies to m1v1o^2 + m2v2o^2 = m1v1f^2 + m2v2f^2 here is where i get stuck, i dont know how to get either v1f or v2f by itself, if i take either the m1v1f^2 or m2v2f^2 to the LHS i still dont know how to solve it. |
| Jun24-09, 07:35 PM | #4 |
Mentor
You have two unknowns. You cannot obtain a unique solution with only one equation. You need two equations.
So, it suffices to solve for one unknown in terms of the other. This amounts to "getting rid of" one of the unknowns, so that you only have one left for the second equation. You know where the second equation comes from, right? |
| Jun24-09, 07:41 PM | #5 |
um no... i have no idea where the second equation comes from :/
| Jun24-09, 07:45 PM | #6 |
Mentor
Hmmm...contrary to what is suggested in your thread title, conservation of kinetic energy and conservation of momentum are two separate conditions. The equation you have written only expresses conservation of kinetic energy (because it says that the total kinetic energy before the collision is equal to the total kinetic energy after the collision).
Momentum is also conserved, so you have another equation that says: total momentum before collision = total momentum after collision
| Jun24-09, 07:48 PM | #7 |
oh ok, so i have:
1/2 m1v1o^2 + 1/2 m2v2o^2 = 1/2 m1v1f^2 + 1/2 m2v2f^2 and m1v1o + m2v2o = m1v1f + m2v2f then i would find a value for say v2f in terms of v1f and then plug that into the first equation? would that work? |
| Jun24-09, 07:50 PM | #8 |
Mentor
| Jun24-09, 07:56 PM | #9 |
ok thatnks, i'll try that.
and ill post again if i have any problems |
| Jun24-09, 08:11 PM | #10 |
ok so i rearanged the momentum equation and got...
(m1v10+m2v20-m1v1f)/m2 = v2f does that look kinda right? also, would the m2 in the m2v20 cancell out? |
| Jun24-09, 08:13 PM | #11 |
wait! then you would work out the equation and then sub it into the energy one right? so youd have a number then v1f and then you could use that in the energy equation
| Jun24-09, 08:22 PM | #12 |
Mentor
| Jun24-09, 08:37 PM | #13 |
gah. i think i did something wrong...
i used the values... m1=1310kg, m2=1001kg, v10=22.2m/s, and v20=27.78m/s and i got to the last step on my equation, and i cant finish it off... -1381.68 = v1f^2 and you cant square root a negative number and get a real answer |
| Jun24-09, 08:39 PM | #14 |
Mentor
I can't help you figure out the problem unless if you post your steps. Start with the point where you substituted the expression for v2f into the energy equation.
| Jun24-09, 08:53 PM | #15 |
ok, well i figured out that (m1v10+m2v20-m1v1f)/m2 = v2f
i then substituted m1=1310kg, m2=1001kg, v10=22.2m/s, and v20=27.78m into the equation and got v2f = 56.83 - 1.31v1f (i wasnt sure if you could completely eliminate the 56.83, and i couldnt figure out how to with out making the expression completely weird) then i put it into the 1/2 m1v1o^2 + 1/2 m2v2o^2 = 1/2 m1v1f^2 + 1/2 m2v2f^2 equation... 1/2 m1v1o^2 + 1/2 m2v2o^2 = 1/2 m1v1f^2 + 1/2 m2v2f^ 1/2 x 1310 x 22.2^2 + 1/2 x 1001 x 27.78^2 = 1/2 x 1310 x v1f^2 + 1/2 x 1001(56.83 - 1.31v1f)^2 322810.2 + 386250.0642 = 655v1f^2 + 500.5(56.83 - 1.31v1f)^2 322810.2 + 386250.0642 = 655v1f^2 + 500.5 x 3229.6489 + 500.5 x 1.72 v1f^2 709060.2642 = 655v1f^2 + 1616439.274 + 860.86v1f^2 -907379.0103 = 1515.86v1f^2 -598.59 = v1f^2 when i did (56.83 - 1.31v1f)^2 was i supposed to square 1.31v1f or -1.31v1f ? cause if i was only supposed to square 1.31v1f then minus it later, that might be where it's wrong |
| Jun24-09, 08:58 PM | #16 |
ok so i just did it with squaring 1.31v1f and it worked out as 209.91 and i think it was m/s which seems wrong. considering that they were originally travelling at 22.2m/s and 27.78m/s so i dont know if thats right
| Jun24-09, 09:17 PM | #17 |
Mentor
(a + b)2 = (a + b)(a + b) = a*a + a*b + b*a + b*b = a2 + 2ab + b2 In this case, b is negative. a = 56.83 b = -1.31 So what is b*b? b*b = (-1.31)*(-1.31) Does that answer your question? |
| Thread Closed |
Similar discussions for: Momentum and Kinetic Energy Equation for Elastic Collisions
| Kinetic Energy and Inelastic Collisions | General Physics | 50 | ||
| Momentum and Elastic Collisions | Introductory Physics Homework | 6 | ||
| Momentum- elastic collisions | General Physics | 3 | ||
| [SOLVED] kinetic energy with momentum equation | Introductory Physics Homework | 4 | ||
| Kinetic energy changes in collisions | Introductory Physics Homework | 1 | ||
