Rechargeable Batteries for Control System w/ 150mA Current | Advice?
  • Thread starter Thread starter EEintern
    Batteries
The discussion centers around the feasibility of using rechargeable batteries in a control system that requires continuous power, specifically exploring the possibility of recharging while in use. The context includes considerations of solar charging and the electrical characteristics of the system, including current draw and voltage requirements.
  • One participant inquires about the existence of batteries that can recharge while powering a control system, which draws 150mA at 9-12 VDC.
  • Another suggests that if a solar panel can supply 300mA, it could simultaneously power the control circuit and recharge the battery.
  • Some participants assert that it is not possible to charge and drain a battery at the same time, likening it to using a machine as both a motor and generator.
  • Contrarily, others argue that it is feasible to charge and use rechargeable batteries simultaneously, provided the solar charger does not damage the batteries and can supply sufficient current.
  • A participant outlines a typical solution involving defining four critical voltages to ensure proper operation and charging of the system.
  • There is a contention regarding the nature of current flow, with some stating that current cannot flow into and out of the battery simultaneously, while others believe that it can depending on the voltage levels of the charger and battery.
Participants express conflicting views on whether it is possible to charge and discharge a battery at the same time, leading to an unresolved debate on the topic.
Participants reference specific electrical principles and scenarios, such as the operation of car batteries and alternators, to support their arguments. However, the discussion lacks consensus on the mechanics of charging and discharging simultaneously.
EEintern
are there batteries that recharge while they are in use? basically, the context is that i need a battery to be powering a control system all the time, but this battery will obviously drain. i wanted a solar recharger so there is no maintenance, but now I'm not even sure if this type of system exists.
the control system only draws 150mA of current and can have 9 - 12 VDC input.
any advice?
If the solar panel can supply 300 mA for example, then divert 150 mA to the control circuit, and the other 150 mA to recharge the battery
You can not drain and charge a battery at the same time. Thats like using a electrical machine as a motor and a generator at the same time. Like what suggestion you can manage the power between both of the components but you can't have your load in the same circuit as your charging circuit.
There is no problem in charging and using rechargeable batteries at the same time. As long as the solar charger does not damage the batteries when they are not in use, the batteries can be recharging while the batteries are being used. If the solar cells cannot supply enough current to supply the cuurent drain when the batteries are in use, the actual current drain will be reduced by the current from the solar cells.
I can drive my car with the headlights on and the air conditioner running, while the alternator is recharging my battery.
The typical solution (for DC applications, at least), is to define four voltages:
(1) the minimum voltage your load needs to operate
(2) the battery voltage when at a full state-of-charge
(3) the battery voltage when nearly empty
(4) the voltage supplied by the charger circuit
Make sure that (2) and (3) are greater than or equal to (1). Also, make sure that (4) is greater than (2); in other words, make sure that charger is capable of trickle charging the battery when it's full.
For example: Car electronics need 12V to operate. Car batteries provide 13.4V or so when full. The alternator, which charges the battery, generally produces about 14V.
- Warren
I don't think this is true. If the charger and battery are in parallel, the battery will supply energy to the circuit if its voltage is higher than the charger and pull energy from the circuit if its voltage is lower. That's what happens when you jump start a car.
Yes, but you are not charging and discharging the battery at the same time in that situation. The battery is in one state or another, charging or discharging. Current either flows into the battery, or out of the battery, not both.
Topher925 said:
.. Current either flows into the battery, or out of the battery, not both.
Exactly, not both at the same time. Current flow is the key here.
