Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image Special Relativity Basics Share It Thread Tools Search this Thread image
Old Jun30-09, 02:36 PM                  #1
JM
JM is Offline:
In his 1905 paper Einstein introduced two coordinate systems which he called K and k. It seems that both systems are inertial because there are no external forces and they are moving at the constant relative speed v.
But I'm not certain, so are they both inertial? Is it correct that either one can be considered the 'stationary' system and the other one the 'moving' system?
Old Jun30-09, 02:53 PM                  #2
George Jones
PF Mentor
George Jones's Avatar
George Jones is Online:
Re: Special Relativity Basics
Yes and yes.
Old Jun30-09, 03:18 PM                  #3
JM
JM is Offline:
So, with K( X,Y,Z,T) stationary the clocks of k( x,y,z,t) are moving in the + X direction at speed v. Putting X=vT in the transfforms leads to t=T/m, where m is the quantity Einstein calls beta. So t is less than T.
With k being stationary the clocks of K are moving in the -x direction at speed v. Putting x=-vt in the transforms leads to T=t/m, ie T is less than t.
Is there general agreement with this result? Is everyone OK with it?
Old Jun30-09, 03:24 PM                  #4
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Yes, an observer in the K system would take the K system as stationary, K' as moving, and observe time in the K' system, t', as slower than t in the K system. An observer in the K' system would take the K' system as stationary, K as moving, and observe time in the K system, t, as slower than t' in the K' system.
Old Jun30-09, 03:34 PM                  #5
Naty1
Naty1 is Offline:
Recognitions:
PF Contributor PF Contributor
Yes.....It will have to do until a better theory is developed!
Old Jun30-09, 03:37 PM                  #6
JM
JM is Offline:
Thanks to you both. So can this example be generalized to say that ' Any analysis carried out with K stationary can also be carried out with k stationary, with suitable choice of k coordinates' ? ( In the example the -x coordinate was considered equivalent to the +X coordinate.)
Old Jul4-09, 06:43 PM                  #7
JM
JM is Offline:
To continue:
The 1905 paper adopted K as the stationary system for all its analysis. For the 'clock paradox' the result was t=T/m, the same as the slow clock.
Based on the above discussion, k can be chosen as stationary, and the 'clock paradox' calculated using the same concepts and math, resulting in T=t/m.
These results are compatible because the comparison is between the time of the stationary system and the time of the moving system 'as viewed from the stationary system'
The equivalence of K and k has apparently been overlooked, and consequently many writers have treated K as the only alternative, and have extensively elaborated this case.
OK?
Old Jul4-09, 07:12 PM       Last edited by JesseM; Jul4-09 at 08:19 PM..            #8
JesseM
JesseM is Online:
Recognitions:
To continue:
OK?
What specific part are you referring to when you talk about the "clock paradox"? Is it this part from section 4 of the paper?
From this there ensues the following peculiar consequence. If at the points A and B of K there are stationary clocks which, viewed in the stationary system, are synchronous; and if the clock at A is moved with the velocity v along the line AB to B, then on its arrival at B the two clocks no longer synchronize, but the clock moved from A to B lags behind the other which has remained at B by (1/2)t*v^2/c^2 (up to magnitudes of fourth and higher order), t being the time occupied in the journey from A to B.
It is at once apparent that this result still holds good if the clock moves from A to B in any polygonal line, and also when the points A and B coincide.
If we assume that the result proved for a polygonal line is also valid for a continuously curved line, we arrive at this result: If one of two synchronous clocks at A is moved in a closed curve with constant velocity until it returns to A, the journey lasting t seconds, then by the clock which has remained at rest the travelled clock on its arrival at A will be (1/2)t*v^2/c^2 second slow.
Is so, note that there is an asymmetry in how the problem was described--he said that the two clocks were synchronized in the K frame up until the moment clock A was moved. This is crucial to understanding why clock A is the one that is behind when the two clocks meet. If he had instead said the clocks were still at rest in the K frame, but synchronized in the k frame, and then when clock A was accelerated it came to rest in the k frame while B continued to move towards it in the k frame (i.e. B continued to be at rest in the K frame), then in that case it would be clock B that was behind when they met.
Old Jul6-09, 12:20 PM                  #9
JM
JM is Offline:
Hello again, JesseM,
Yes, I refer to p.4 of '1905.
I agree with your description of the original 'clock paradox'. A and B start at rest in K, A moves and returns, and A ends up slow compared to B.
From your last sentence I gather that you recognize a valid alternative analysis of the clocks where B ends up slow compared to A.
Do you think that these two results are compatible, and that the results apply to the 'twin paradox?
Old Jul6-09, 12:48 PM                  #10
JesseM
JesseM is Online:
Recognitions:
It's not just an alternative "analysis" of the same physical situation though, it's an actually physically distinct scenario where the two clocks have initially been synchronized differently. In any given physical scenario involving two clocks that meet, there will be only one correct answer to what the clocks read at the moment they meet.
Again, the alternative physical scenario I mentioned doesn't contradict the fact that in the scenario as Einstein defined it, clock A will definitely be behind clock B, this is true regardless of what frame you analyze the scenario in. Likewise, in the twin paradox you will find that the inertial twin elapsed more time than the twin who accelerated regardless of which frame you use to analyze the voyage.
Old Jul8-09, 08:31 AM                  #11
JM
JM is Offline:
JesseM,
Please listen-
I have already said that I agree with Einsteins analysis.
What I am saying is that k has an equal right to consider himself to be stationary! Thus , if K sees k moving away, turning around, and returning, then k, considering himself to be stationary,sees K moving away, turning around and returning. Then by your description, k being stationary elapses more time than K who turns around. Einstein did not describe this situation.
Do you deny k the right to consider himself stationary?
Old Jul8-09, 08:36 AM                  #12
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
JesseM,
Please listen-
If k is not inertial, then k cannot be stationary, in any inertial frame. If k turns around, then k is not stationary, and there is no symmetry between k and K. But I don't think Einstein gave a single co-ordinate system for an observer that turned around and came back. You can't given an inertial co-ordinate system for such an observer.
Old Jul8-09, 02:40 PM                  #13
JesseM
JesseM is Online:
Recognitions:
JesseM,
Please listen-
What do you mean "moving away, turning around, and returning"? That would suggest that k and K are not moving inertially relative to each other as Einstein defined them to be. In the clock scenario, I was assuming k was the inertial frame where A and B were initially moving at the same constant speed, then after A accelerated A was at rest in k while B continued to move at the same constant speed until it met with A and they compared clock readings. Are you thinking of k as a non inertial frame whose velocity in K's frame is not constant for all eternity? In this case k would not have an equal right to consider himself stationary and use the ordinary SR time dilation equation to calculate the time elapsed on moving clocks, because the SR time dilation equation only works in inertial frames. And remember, there is an absolute truth in SR about whether a given observer is moving inertially or non-inertially--a non-inertial observer will feel G-forces as he accelerates which can be measured by an accelerometer he carries alongside himself.
Old Jul10-09, 08:33 AM                  #14
JM
JM is Offline:
Lets attend carefully to what Einstein said as quoted be JesseM in his post no.8.
The first paragraph, 'From this...', is his statement of the 'slow clock' idea. His result is the approximation of the square root in the formula t=T/m, see post 3. I have identified clock B with K and clock a with k to agree with Einsteins definitions in his par. 3, where K is stationary and B doesn't move and k and clock A move. Both A and B are inertial.
In the second par. he says 'It is at once apparent that this result still holds good if the clock moves from A to B in any polygonal line, and also when the points A and B coincide.'
By 'this result' he clearly means the 'slow clock' formula he just derived in the immediately preceding par. In addition he cites the 'slow clock' formula in the third par. regarding the continuously curved line.
Thus he is saying that the time lag experienced by a clock moving in a closed curve is the same as the lag experienced by a clock moving in a straight, inertial line. So he is totally ignoring any effects of accelerations, or any other effects of the curved or segmented path of the moving clock.
Since A and B are both inertial, either may consider himself to be stationary. The reasoning of the first par. is equally valid with A stationary and B moving, with the resulting time lag expressed by T=t/m.
Old Jul10-09, 10:18 AM       Last edited by sylas; Jul10-09 at 10:37 AM..            #15
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
Good grief, no.
k is NOT the clock moving in polygons. It is a single inertial co-ordinate system, for the single leg moving from A to B. The "result that holds good" is that the clock moved from A to B ends up lagging behind the clocks at A and B which are synchronized in frame K.
Hence, when you continue to move the clock in a new direction but at the same speed, it will continue to lag further and further behind clocks that are at rest wrt A and synchronized with A. Hence, the end result is that the clock moving in a closed curve from A back to A again ends up by showing less time -- lagging behind -- the clock which remains at A throughout. THAT is what Einstein is saying if you play careful attention to his words; in terms of the twin paradox, the twin that moves in a curve is the one that ages less.
I've seen these kinds of discussions before; so be aware, I have no interest in arguing with you if you take the line that you are reading correctly and trying to explain Einstein. Einstein is quite clear and speaks for himself with admirable clarity... and you've misunderstood it. I can help explain if you are are genuinely uncertain.
Nothing in Einstein's words suggests that there's a frame "k" which applies for the clock all through its polygon or curved trip from A back to A again.
Cheers -- sylas
Old Jul10-09, 03:58 PM                  #16
JesseM
JesseM is Online:
Recognitions:
But the "slow clock" formula is just meant to calculate the time elapsed on a clock which is moving in whatever inertial frame you're using. It is indeed true that if you pick different inertial frames K and k, and use them to analyze the time elapsed on a clock which moves on a polygonal line (an approximation to a continuous curve), you can use the same time dilation formula in each frame to calculate the time elapsed on each segment of the polygon--this would just be (difference in time coordinates between the beginning and end of the segment in your frame)*(time dilation factor in your frame)--and add them up to get the total time elapsed on the polygonal path, and both frames will end up predicting exactly the same time elapsed (if you like I could given an example of a simple polygonal path analyzed in different frames). But nowhere did Einstein mean to suggest that the same time dilation formula could be used in a non-inertial frame!
No, he certainly isn't! He's just saying you can break the polygonal path into segments and calculate the time elapsed on each segment the same way you would for the time between two events on the path of an inertial clock, then add up the segments to find the total time elapsed. But again, for each segment you must use an inertial frame to calculate the time elapsed (though it's not necessary to use the same inertial frame for different segments, since all frames make the same prediction for the time elapsed on a given segment).
Of course you are also free to take the worldline of the clock B that never changes its velocity and divide it into segments, calculating the time elapsed on each segment and adding them up to find the total time elapsed. But if you do this you must make sure that the end of each earlier segment corresponds to the same event as the beginning of the next segment. So you can't have one segment's end be "the event on clock B's worldline that's simultaneous with clock A accelerating in frame K", and the beginning of the next segment be "the event on clock B's worldline that's simultaneous with clock A accelerating in frame k", because according to the relativity of simultaneity these are two entirely different events which may leave an unaccounted-for section of B's worldline between the end of the first segment and the beginning of the second.
image image
Reply
Thread Tools
Similar Threads for: Special Relativity Basics
Thread Thread Starter Forum Replies Last Post
How much is Special Relativity a needed foundation of General Relativity lalbatros Special & General Relativity 74 Nov10-09 12:18 PM
Questioning examples often used to introduce the basics of relativity sumofprimes Special & General Relativity 17 May7-08 03:49 PM
A Question About Special Relativity's Basics Sleek Special & General Relativity 2 Dec27-07 11:33 PM
Does G.Relativity Violate Energy Basics? omin General Physics 27 Aug9-04 02:48 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
