Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image When does Newton's Gravitation fail us? Share It Thread Tools Search this Thread image
Old Jun30-09, 08:31 PM                  #1
physicsdude30
physicsdude30 is Offline:
I am trying to learn more about General Relativiity. We had Newton's Law of Gravitation. When does it not work? I heard at very high speeds, high mass bodies, and when the distance to a high mass body is very short (Mercury for example, I think)? How does Newton's Gravitation differ mathematically in these scenarios?
Old Jul4-09, 05:08 AM                  #2
A.T.
A.T. is Offline:
Re: When does Newton's Gravitation fail us?
The difference in acceleration for a vertical fall is discussed here:
http://www.physicsforums.com/showthread.php?t=310397
But GR also predicts other effects, like gravitational time dilation and trajectories altered by the curvature of space (Mercury orbit precession), which are missing in Newtons theory.
Old Jul6-09, 03:49 AM                  #3
Matterwave
Matterwave is Offline:
Also, the bending of light near a star is purely from GR. Newtonian physics would have light not bend at all near a star since light is mass-less. Even if you attribute a "pseudo mass" (using E=mc^2) to photons, Newton's predictions of the bending of light are only half the actual bending of light (as observed and predicted by GR).
Old Jul6-09, 03:57 AM                  #4
Vanadium 50
PF Mentor
Vanadium 50's Avatar
Vanadium 50 is Offline:
Not so. Newtonian physics postulates acceleration independent of mass.
That is true.
Old Jul6-09, 04:22 AM                  #5
Matterwave
Can you kindly refresh my memory on why Newtonian physics would predict a bending of light even if we say that it is massless?
I only remember F=GMm/r^2 which would obviously be 0 if one of the m's were 0.
Old Jul6-09, 04:30 AM                  #6
A.T.
A.T. is Offline:
Bending of a trajectory is a result of acceleration, and there is no m in the formula for that: g = GM/r^2
Old Jul6-09, 05:17 AM                  #7
Matterwave
Sounds very iffy to me.
Getting that formula g=GM/r^2 is done by doing: mg=GMm/r^2 is it not? In which case, you cancel the two lower case m's and you get g. You can't do that if the lower case m is 0, that's dividing by zero and is a classic way of getting ridiculous results.
I suppose you could justify it using limits...
g=GMm/mr^2 and then take the limit as m goes to 0. But it still looks iffy to me. I mean, how can you even apply F=ma if m=0?
Old Jul6-09, 06:14 AM                  #8
DaleSpam
DaleSpam is Online:
Recognitions:
Nothing iffy about it. If you have a massless particle then any non-zero force will give it an infinite acceleration. If you want a finite acceleration the force must be 0.
Old Jul6-09, 08:06 AM                  #9
A.T.
A.T. is Offline:
You can get the acceleration by directly observing the trajectories, which turn out to be independent of m. The formula for the gravitational force is derived from this. You have to keep in mind that force is rather an abstract concept, while trajectories/acceleration are observed directly.
Old Jul6-09, 08:24 AM                  #10
P3X-018
P3X-018 is Offline:
You can't bend a trajectory without a force. The acceleration is just the result of the force between the bodies attracting each other. Gravity doesn't affect massless particles in the classical mechanics.
Old Jul6-09, 08:30 AM                  #11
Vanadium 50
PF Mentor
Pierre-Simon Laplace would be very surprised to read that. He proposed black holes - bodies so massive that even light could not escape - and his argument relied on the universal acceleration of bodies in free fall.
This was in 1799.
Old Jul6-09, 08:39 AM                  #12
P3X-018
P3X-018 is Offline:
This was in 1799.
Then please enlighten us on how gravity interacts with massless particles. Are you sure light is assumed to be massless for that statement?
"Bodies in free fall" already assumes mass.
Old Jul6-09, 09:54 AM                  #13
DaleSpam
DaleSpam is Online:
Recognitions:
This really is the key point.
Old Jul6-09, 03:43 PM       Last edited by A.T.; Jul6-09 at 04:32 PM..            #14
A.T.
A.T. is Offline:
So how much force do I need to bend the trajectory of a massless particle?
Acceleration is an observed quantity. Force is just a derived concept that makes sense for massive particles only.
Newtonian gravity accelerates objects independently of their mass. That is the observed reality. From that you can derive F=GMm/r^2 via F=ma, but only for massive objects. For massless objects F=ma is not applicable, and so neither is F=GMm/r^2. Therefore you cannot use F=GMm/r^2 to show that massless objects are not affected by Newtons gravity.
Old Jul6-09, 04:00 PM                  #15
JesseM
JesseM is Online:
Recognitions:
PF Contributor PF Contributor
Yes, it's natural to justify it using limits--since an object's acceleration in a gravitational field can be shown to be independent of its own mass for any nonzero mass, this is obviously going to be true in the limit as a particle's mass approaches zero.
Old Jul8-09, 04:01 PM                  #16
JanClaesen
JanClaesen is Offline:
If you put a heavy bowling ball on a trampoline it will roll to its center and sink in a way that if you put some tennisballs on the trampoline that they will roll to the bowling ball, this we experience as gravity. Is this a valid comparision? The author says the example is in 2D, but if the ball sinks, isn't that 3D? (Is that perhaps why a fourth dimension is added in relativity?)
image image
Reply
Thread Tools
Similar Threads for: When does Newton's Gravitation fail us?
Thread Thread Starter Forum Replies Last Post
Newton's Law of Gravitation science_rules Introductory Physics 5 Apr6-09 08:20 PM
Newton's Law of Gravitation (again) Benzoate Advanced Physics 3 Sep14-08 10:18 PM
Newton's Law of Gravitation John Creighto Classical Physics 2 Feb2-08 02:46 PM
Newton's Law of Gravitation Shadow Cloud Introductory Physics 7 Dec1-05 09:56 PM
Newton's Law of Gravitation nlink1979 Introductory Physics 2 Nov3-03 02:58 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
