Number of sp3-Hybridized Carbon Atoms in Tamoxifen
  • Thread starter Thread starter kathyt.25
    Carbon
The discussion revolves around determining the number of sp3-hybridized carbon atoms in the chemical compound tamoxifen. Participants explore the concept of hybridization in carbon atoms, particularly in the context of organic chemistry, and how it relates to the types of bonds formed (single, double, triple).
  • Homework-related
  • One participant questions whether all carbon atoms in tamoxifen are sp3-hybridized and expresses confusion about how hybridization varies with different types of bonds.
  • Another participant explains that sp3-hybridized carbons form four single bonds and encourages the original poster to identify such carbon atoms in tamoxifen.
  • Several participants express uncertainty about the concept of hybridization and seek clarification on why single, double, and triple bonds correspond to sp3, sp2, and sp hybridization, respectively.
  • A participant introduces the concept of "domains" of electron density and explains how to determine hybridization based on the number of these domains around a carbon atom.
  • Another participant provides a detailed explanation of the geometry of orbitals and how hybridization reconciles observed bond angles with the shapes of s and p orbitals.
  • There is a discussion about the specific cases of hybridization for different compounds, such as methane (CH4), ethene, and ethyne, with emphasis on the number of bonds and lone pairs affecting the hybridization state.
Participants do not reach a consensus on the exact number of sp3-hybridized carbon atoms in tamoxifen, and there is ongoing uncertainty regarding the understanding of hybridization concepts.
Participants mention the need to count "domains" around carbon atoms, but the definitions and implications of these domains are not fully resolved. There is also a lack of clarity on how to apply these concepts specifically to the structure of tamoxifen.
kathyt.25
How many sp3-hybridized carbon atoms does tamoxifen possess?
This is tamoxifen:
http://en.wikipedia.org/wiki/File:Tamoxifen_Structural_Formulae.png2. The attempt at a solution
Are all carbons sp3-hybridized? Does the hybridization of carbon vary, depending on the bonds (ie. single, double, triple), and what it bonds to?
This is a multiple choice question, and the options are 2, 4, 6, 7, and 11... so it wouldn't work if I just counted the number of carbons (there would be 26). If this is the case, I don't understand how to determine the number of sp3-hybridized carbons. Wouldn't carbon ALWAYS be sp3-hybridized, since there are three 2p orbitals, and one 2s orbital that holds carbon's valence electrons?
You don't seem to understand hybridisation very well.
Remember that hybridisation is a theory used to explain the way the bonds are shaped, so yes it will depend on the bond geometry. But basically sp3-hybridized carbons form 4 single bonds (you have 4 hybrid orbitals, as the name sp3 suggests), so just look for such carbon atoms. It will turn out to be one of the choices, don't worry! Those involved in double bonds are typically sp2 hybridized , triple bonds are sp hybridized.
Hmm... I counted six. What did you get?:biggrin:
Yeah, I don't think I understand hybridization that well either. Can you explain why single bonds are sp3-hybridized, double bonds are sp2-hybridized, and triple bonds are sp hybridized?
You're suppose to count the domains around the carbon. Do you know how to do that?
What do you mean by domains?
The full explanation is quite involved imo.
The way to *deduce* the hybridization is to look at bond geometry, i.e. how the bonds and surrounding atoms are arranged. The "domains" wax refers to are domains of electron density, which essentially means where the electrons are. For example each C-H bond as a "domain" between the C & H atom. So CH4 has 4 domains. C=O bond, although being a double bond, is counted as one domain. So each carbon in ethene has 3 domains, and for ethyne, 2 domains.
4 domains -->sp3
3 domains -->sp2
2 domains -->sp
Now, as for WHY CH4 carbon is called sp3, etc.
Carbon has 4 valence electrons, and you should be familiar with the concept of s and p orbitals. On its own, 2 electrons will be in the single s orbital, and 2 others in one p orbital each. @kathy, only occupied orbitals count! You should also be familiar with the geometry of these orbitals: s orbital looks like a sphere, each p orbital looks like a dumbbell, perpendicular to each other. Yet experiments show that in CH4 (and similar carbons forming 4 single bonds) the bonds are symmetrically distributed about the central carbon atom, with bond angles of about 109.5 degrees.
Now, that appears to contradict what we know about s and p orbitals! To reconcile this fact, the theory of hybridization says that during bonding, the s and p orbitals "hybridize" to form 4 new orbitals in a tetrahedral shape, which then participate in bonding. It's called sp3 as one s orbital and three p orbitals are involved.
"Now hold on, you said we had one s orbital and 2 p orbitals!" For an electron to be involved in bonding, it must reside in a singly occupied orbital, so that it can pair up with another electron in a singly occupied orbital on the other atom to form a bond. So the theory goes that one electron is promoted from s orbital to a vacant p orbital somehow.
With me so far? If so, we can extend this to explain why double bond is sp2. *Do take note that this is the case only if the carbon has one double bond and 2 single bonds*. Take ethene for example. Only 3 electrons are involved in direct covalent bonding, thus sp2. (Remember we still have to promote the s electron). There is a leftover electron in each carbon in an UNHYBRIDIZED p oribtal, perpendicular to the plane of the sigma C-C bond, which then forms the pi bond.
For triple bonds, as in ethyne, C is sp hybridized, using the same logic. But note that O=C=O is also considered sp hybridized! Can you figure out why?
Are you taking Organic Chem Kathy? I'm assuming you are since you posted that compound. Anyway, counting domains is really easy to do. It's just hard to explain. :cry:
Trying to keep it simple, just count the groups around the carbon.
Lone pair = 1 group
Single bond = 1 group
Double bond = 1 group
Triple bound = 1 group
4 groups-->sp3
3 groups-->sp2
2 groups-->sp
  • · Replies 18 ·
