Is Quantum Physics the theory of everything if
Quantum Physics does not serve as the definitive theory of everything, particularly in the context of low-energy and low-gravity phenomena. While it can provide consistent predictions for such phenomena, it fails to explain certain fundamental aspects, such as the specific mass of the electron. The discussion highlights that although quantum physics allows for various electron masses, it does not provide a concrete explanation for why the electron has its particular mass. Thus, while quantum physics is consistent with many low-energy phenomena, it does not encompass all explanations required for a comprehensive understanding.
  • Understanding of Quantum Physics principles
  • Familiarity with General Relativity (GR)
  • Knowledge of particle physics, including fermions and bosons
  • Basic concepts of energy and gravitational fields
  • Research the limitations of Quantum Physics in explaining fundamental particle masses
  • Explore the relationship between Quantum Physics and General Relativity
  • Study the implications of low-energy phenomena in Quantum Field Theory
  • Investigate the unification of fundamental forces in theoretical physics
Students and researchers in physics, particularly those focusing on Quantum Physics, General Relativity, and particle physics. This discussion is beneficial for anyone interested in the limitations and applications of Quantum Physics in explaining low-energy phenomena.
Delta2
Insights Author
Hello i am new to forum, and relatively new to Quantum physics study.
I know that Quantum Physics cannot explain all the physical or universal phenomena, BUT:
Provided that gravitational fields are weak, and we have to do with phenomena at low energies , so that the distortion of space and time (as desicribed by GR ) is negligible, is Quantum Physics the theory of everything? Can quantum physics explain all those phenomena falling into the former category (low gravity-low energy, with flat spacetime)?
Are there any phenomena associated with low energies and low gravity that quantum physics cannot give an explanation?
P.S I am not talkin about unification of the fundamental forces, as there are fermion and bosons which arent the same thing, there might as well be nuclear force and electromagnetic force and electroweak force which need not to be the same.
I wouldn't say that quantum physics can EXPLAIN all low-energy phenomena, but I think it is safe to say that all such phenomena are CONSISTENT with quantum physics. For example, quantum physics cannot explain why the mass of the electron is such as it is, but such mass is consistent with it because quantum physics allows any mass of the electron.
Well the way i mean explanation is the way u perceive consistency ). To be honest you expressed my question (and the answer) in a more accurate way than i did. My main concern is if quantum physics facing a low energy phenomenon, will give a prediction, calculation, or an answer (explanation) that is consistent with the experimental data. In the case of the mass of electron, quantum physics give an answer "it can be anything" which ofcourse is in constistency with the experimental data (at low velocities, at high ones the answer still seems to be consistent but much of quantum physics arent,as the electron mass and energy increases following the increase in velocity, quantum physics start breaking down).
  • · Replies 26 ·
  • · Replies 41 ·
  • · Replies 36 ·
  • · Replies 23 ·
  • · Replies 18 ·
