What is the Approximate Index of Refraction of a Transparent Liquid?
  • Thread starter Thread starter Perrin
    Optics Refraction
The discussion focuses on calculating the approximate index of refraction of a transparent liquid with a depth of 10 cm, using Snell's law. The user applies the formula sin(alpha1)/sin(alpha2) = n2/n1, where n1 is the index of refraction of air (1). By employing the Pythagorean theorem to derive the relationships between distances, the user concludes that the index of refraction n2 depends on the variable x, which represents the distance from the object to the mirror. The user successfully determines that using a small value for x yields an approximate solution, affirming the validity of this approach.
  • Understanding of Snell's law and its application in optics.
  • Familiarity with the Pythagorean theorem for calculating distances.
  • Basic knowledge of the concept of index of refraction.
  • Experience with geometric optics and image formation in liquids.
  • Study the derivation and applications of Snell's law in various media.
  • Explore the principles of geometric optics, focusing on image formation.
  • Learn about the effects of varying indices of refraction on light behavior.
  • Investigate the relationship between depth and clarity of images in different liquids.
Students in physics, particularly those studying optics, as well as educators and anyone interested in understanding the principles of light refraction in transparent media.
Perrin
The original problem:
A plane mirror is placed horizontally at the bottom of a transparent liquid of 10 cm depth. When one looks at the image of a small object floating at the surface of the liquid right above the object, the image is seen at 14 cm below the surface of the liquid. Find the approximate value of the index of refraction of the liquid.
I used Snell's formula:
http://www.dotcore.co.il/refraction_problem.jpg
I really hope this image is clear enough, unfortunately that's the top of my Gimp skills...
I said:
sin(alpha1)/sin(alpha2) = n2 (n1 = 1 because it's the index of refraction of air)
sin(alpha1) = BF/AF, sin(alpha2)=DC/AC
DC=FB=x, because the image as seen by the observer as result of the refraction is right above the original image
So:
n2 = (x/AF)/(x/AD) = AD/AF
According to the Pythagorean theorem:
AD = sqrt(x^2 + 20^2)
AF = sqrt(x^2 + 14^2)
Now to my problem:
Certainly, n2 depends on x. I remember my textbook saying that a point below the surface of a material with a higher index of refraction does not create a clear image, is that the reason of the dependency of n2 on x?
The book also said that for small distances, the image can be seen clearly. Does that mean that I can plug in a small value for x to get the correct answer? I tried plugging in x=0, and I got a correct answer. Is it valid to do that? Is that the reason the problem states "Find the approximate value"?
Thanks in advance for the help!
Perrin.
Pretty much that looks like it.
For a small angle I think you can reasonably take AF ≈ AB and AC ≈ AD.
OK, thanks for affirming my answer! I can sleep peacefully tonight :D
  • · Replies 24 ·
