Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image Functionals Share It Thread Tools Search this Thread image
Old Jul4-09, 02:55 PM                  #1
CFDFEAGURU
CFDFEAGURU's Avatar
CFDFEAGURU is Offline:
Recognitions:
PF Contributor PF Contributor
Functionals
Hello all,
I have been trying to fill in the gaps in the example of a functional given in chapter 3 of Hartle's book "Gravity" and I am not having much luck. I exhausted wikipedia for help to no avail. Does anyone know of or can provide a good simple example of a functional or just the Lagrangian?
Thanks
Old Jul4-09, 04:14 PM                  #2
jambaugh
jambaugh's Avatar
jambaugh is Offline:
Recognitions:
Re: Functionals
A functional is simply a function whose domain is a set of functions. i.e. a functional is a mapping from a function to a number.
Example: [The value of the function at x=0]
maps cos to 1, maps sin to 0, and maps a polynomial to the value of its constant term.
Example: Given x as a function of t representing an arbitrary (smooth) particle trajectory,
LaTeX Code:  x \\mapsto S= \\int_{t_1}^{t_2} \\frac{m}{2} \\dot{x}^2(t) - V(x(t)) dt
maps the whole trajectory of the particle to a single number, S we call the action. V is a potential function defining the potential energy for the particle at any position x.
This is the canonical action for a particle with mass m.
The action integral is the functional. The lagrangian is the integrand we use to define the functional. Generically we have:
LaTeX Code:  x \\mapsto S= \\int_{t_1}^{t_2} L(x,\\dot{x},\\ddot{x},...)dx
Since a functional is also a type of function we can consider its differentials which are variations in the value of the functional LaTeX Code:  \\delta S which depend on variations in the function itself. You will then see that LaTeX Code: \\delta S will be a functional depending on the function x(t) and its variation (functional differential) LaTeX Code: delta x (t) .
If you imagine an analytic function as defined by its power series expansion:
LaTeX Code: x(t) = x_0 + x_1 t + x_2 t^2 + \\cdots
where the LaTeX Code:  x_k coefficients can then be though of as coordinates then you can think of the function itself as an infinite dimensional vector.
Thus a functional is a mapping (possibly non-linear) from this infinite dimensional vector space to a one dimensional vector space.
Note that the first example: [the value of the function at 0]
can be re-expressed also in integral form:
LaTeX Code:  f \\mapsto \\int_{-\\infty}^\\infty f(x)\\delta(x)dx
where we use the Dirac delta function.
More generally we might consider an operator which maps a vector to a vector or a function to a function. Example LaTeX Code: \\frac{d}{dx} .
Most operators on functions can also be expressed in integral form but with an extra variable:
LaTeX Code:  f\\mapsto g: g(x) = \\int_{y_1}^{y_2} f(y)W(x,y)
Some other examples of operators are e.g. Fourier and Laplace transforms.
In summary:
(ordinary) function maps value to value
functional maps function to value
operator maps function to function
Old Jul4-09, 04:15 PM                  #3
George Jones
PF Mentor
George Jones's Avatar
George Jones is Online:
Re: Functionals
A general function LaTeX Code: f is a mapping
LaTeX Code: f : A \\rightarrow B,
where LaTeX Code: A and LaTeX Code: B are sets. Consequently, LaTeX Code: f \\left( a \\right) = b for LaTeX Code: a in LaTeX Code: A and LaTeX Code: b in LaTeX Code: B .
A functional is a special type of function where the elements of LaTeX Code: A are themselves functions and LaTeX Code: B is either the set of real numbers or the set of complex numbers.
Can you see why the Hartle's Lagrangian is a functional?
I don't have my copy of Hartle home with me, but if you want to ask specific questions about what Hartle does, I can have a look on Monday.
[edit]Obviously, James gave a much more detailed answer.[/edit]
Old Jul4-09, 04:28 PM                  #4
Bob_for_short
Bob_for_short's Avatar
Bob_for_short is Online:
Recognitions:
Re: Functionals
functional: maps function to value
It is not really so. A functional is an integral where the integrand is considered as a variable, not a fixed function. Otherwise it is indeed a number.
Old Jul4-09, 04:51 PM                  #5
George Jones
PF Mentor
Re: Functionals
The definition of "functional" which James and I gave is the standard definition that is found in most functional analysis books.
This (with maybe slightly different wording) is a special (i.e., not general) type of functional.
No one said that a functional is a number.
Old Jul4-09, 05:05 PM                  #6
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Re: Functionals
Yes, really so. What you give, an integegral which maps a function to a number by taking a specific integral is an example of a functional, not a general functional.
Old Jul4-09, 05:19 PM                  #7
CFDFEAGURU
CFDFEAGURU's Avatar
Recognitions:
Re: Functionals
The example given in Hartle is
(V(x)=0) defines a free particle moving between points LaTeX Code: _{}x A at LaTeX Code: _{}t A and LaTeX Code: _{}x B at LaTeX Code: _{}t B
In Newtonian physics with a constant velocity of (LaTeX Code: _{}x B-LaTeX Code: _{}x A)/T, where T=LaTeX Code: _{}t B-LaTeX Code: _{}t A When half of the time, T, has elasped the particle is at the position (LaTeX Code: _{}x B+LaTeX Code: _{}x A)/2
Now we compare the action of this path satisfying Newton's laws with paths that move from LaTeX Code: _{}x A with a constant velocity to some different position X in total time T/2 and then with a different constant velocity to get to LaTeX Code: _{}x B in time T. The action S(X) for these paths is a function of X, which is easy to calculate from S[x(t)]=LaTeX Code: \\int dt L((xLaTeX Code: ^{.} (t),x(t)) (The limits of integration are LaTeX Code: _{}t A to LaTeX Code: _{}t B) because the velocity is constant on each leg, namely, (X-LaTeX Code: _{}x A)/(T/2) on the first leg and (LaTeX Code: _{}x B-X)/(T/2) on the second. The action along any leg with a constant velocity, V, for a time, t, is mVLaTeX Code: ^{}2 t/2
The sum of both legs is
S(X)=m[(LaTeX Code: _{}x B-X)^2+(X-LaTeX Code: _{}x A)^2]/T
The extremal paths are defined where dS/dX = 0.
The subsequent answer is given, but is that all this is required is to take the derivative of S(X) and then set it equal to zero and then solve for X?
Old Jul4-09, 06:17 PM                  #8
Fredrik
Fredrik's Avatar
Fredrik is Offline:
Recognitions:
Re: Functionals
Originally Posted by CFDFEAGURU View Post
...is that all this is required is to take the derivative of S(X) and then set it equal to zero and then solve for X?
Your notation makes that a pain to read. As for your last question, I'm not sure if you mean "is that all that's required...", "is all this required...", or something else entirely.
One thing you can do to find the function that minimizes the action functional is to consider a one-parameter family of functions LaTeX Code: x_\\epsilon such that LaTeX Code: x_0 is the function that minimizes the action:
LaTeX Code: 0=\\frac{d}{d\\epsilon}\\bigg|_0 S[x_\\epsilon]=\\int_{t_1}^{t_2}dt \\frac{d}{d\\epsilon}\\bigg|_0 L(x_\\epsilon(t),\\dot x_\\epsilon(t))=\\cdots
This condition gives you the Euler-Lagrange equations, which is what you use instead of Newton's second in this formulation of classical mechanics.
Note that the Lagrangian L is just a function of several variables (in this case just two). For example LaTeX Code: (a,b)\\mapsto b^2/2+V(a) is the Lagrangian of a single point particle in one dimension. If we instead consider the map LaTeX Code: x\\mapsto L_t[x]=L(x(t),\\dot x(t)) , Lt is a functional. Actually, it's a different functional for each value of t.
What if the domain of definition is some unspecified vector space. Wouldn't you still call it a functional?
Old Jul4-09, 06:19 PM                  #9
Bob_for_short
Recognitions:
Re: Functionals
If we speak of action S, then the integrand is not only variable function but also an unknown function. So S depends strongly on the integrand. Than is why it is called "functional" (nearly function). A simple integral with a known (fixed) function is a number, not a functional.
The Lagrange equations serve to find the unknown variables. No one injects them, when found, into the action expression. Nobody cares of the action value on the real trajectory.
Old Jul4-09, 06:34 PM                  #10
Fredrik
Fredrik's Avatar
Fredrik is Offline:
Recognitions:
Re: Functionals
I see what you're saying Bob. It's like when people call f(x) a "function". I always find that annoying. f(x) is a number. f is a function. f is the map that takes x to f(x). What you're saying is the corresponding statement for functionals. S[f] isn't a functional. It's just a number. S is a functional. It's the map that takes f (any f in the domain of definition) to S[f].
That's a valid point, but I think it's clear that both George and James understand that. When Jambaugh said "is a mapping from a function to a number" it would have been better to say something like "is a mapping from a set of functions to a set of numbers", but I think it's clear from the rest of what he said that that's what he meant.
Old Jul4-09, 06:42 PM                  #11
Bob_for_short
Recognitions:
Re: Functionals
Yes, I agree, and I believe they understand it right. I just wanted to explain to the author of OP that there is difference between X(t) before finding it and after that. For example, Hamiltonian H is a form containing unknown variables x and p. When found and injected into H, they give the system energy E which is a number. Unfortunately they often denote unknown variables and the equation solutions with the same symbols.
Old Jul4-09, 09:52 PM                  #12
jambaugh
jambaugh's Avatar
Recognitions:
Re: Functionals
Just some followup comments...
One of the virtues of natural language in literature is a detriment in mathematics and that is ambiguity. I like to distinguish: "f is a mapping from (set) A to (set) b" from "f maps a (in A) to b (in B)."
Symbolically we use distinct arrows to make this clear:
LaTeX Code:  f:A \\to B
LaTeX Code: f:a\\mapsto b
this second being equivalent to saying f(a)=b.
Another minor distinction, remember that the Lagrangian is not itself the functional. It together with the domain of integration uniquely defines the action functional so for practical purposes we identify the choice of Lagrangian with the choice of action functional.
Old Jul6-09, 02:18 PM                  #13
CFDFEAGURU
CFDFEAGURU's Avatar
Recognitions:
Re: Functionals
Fredrik,
Sorry for the poor use/abuse of the Latex for the illustration of the mathematics. What I meant to say was that once you obtain this equation S(X)=m[(B-X)^2+(X-A)^2]/T. Is the solution to this equation found by calculating the derivative, setting the derivative equal to zero and then solving for X?
Old Jul6-09, 06:21 PM                  #14
Fredrik
Fredrik's Avatar
Fredrik is Offline:
Recognitions:
Re: Functionals
That example is pretty weird. The goal is to find the function x (out of all the continuous real-valued functions of one real variable) that makes S[x] as small or as large as possible, and you're only considering functions that have a graph that consists of two straight lines.
Old Aug16-09, 12:11 PM                  #15
CFDFEAGURU
CFDFEAGURU's Avatar
Recognitions:
Re: Functionals
Hello all,
Thanks for the advice and definitions above. Here is the problem given in Hartle's book. This is problem 5 in chapter 3.
Consider the functional
S[x(t)] = LaTeX Code: \\int[(dx(t)/dt)^2+x^2(t)]dt
The integral is from zero to T. (Can someone show me how to create an integral with the limits of integration in LaTex?)
Find the curve x(t) satisfying the conditions x(0)=0, x(T)=1. which makes S[x(t)] an extremum. What is the extremum value of S[x(t)]? Is it a maximum or a minimum?
Note: This is not a homework problem. I am teaching myself GR and I just need some help here.
Any help on this would be greatly appreciated.
Thanks
Matt
Old Aug16-09, 12:51 PM       Last edited by Fredrik; Aug16-09 at 12:59 PM..            #16
Fredrik
Fredrik's Avatar
Fredrik is Offline:
Recognitions:
Re: Functionals
Option 1: LaTeX Code: \\int_a^b Option 2: LaTeX Code: \\int\\limits_a^b
First note that S is the functional and that S[x] is a number. The expression S[x(t)] doesn't make sense since it's a functional acting on a number. (See #10). Also note that the integral is of the form
LaTeX Code: \\int_0^T L(xsingle-quote(t),x(t)) dt
and that L is just a polynomial in two variables. There are three options here: a) use the Euler-Lagrange equations, b) derive the E-L equations for an arbitrary L, and then use them for this specific L, c) derive the E-L euqations for this specific integral.
The way I like to derive the E-L equations starts like this: Let x be the function that maximizes or minimizes the integral, and let LaTeX Code: \\{x_\\epsilon\\} be a one-parameter family of functions with LaTeX Code: x_0=x . Now we must have
If you figure out the appropriate way to rewrite the right-hand side, you have found the Euler-Lagrange equations. Post #3 in this thread does this calculation for for a scalar field theory, so you can check that out if you get stuck, but I recommend that you try it yourself first. (Oops, now I see that I omitted some details in the other thread, but it should still be useful).
image image
Reply
Thread Tools
Similar Threads for: Functionals
Thread Thread Starter Forum Replies Last Post
Linear Functionals sharkboy Linear & Abstract Algebra 13 Dec6-07 08:24 PM
Linear Functionals wurth_skidder_23 Calculus & Beyond 3 Dec10-06 05:04 PM
Linear functionals wurth_skidder_23 Calculus & Beyond 6 Sep15-06 04:06 AM
Linear Functionals Questions. MathematicalPhysicist Calculus & Beyond 16 Jun4-06 02:28 PM
linear functionals? UrbanXrisis Calculus & Beyond 9 May4-06 07:48 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
