What current is needed in the solenoid’s wires?
  • Thread starter Thread starter jlmessick88
    Current Wires
The discussion revolves around determining the current required in the wires of a solenoid to cancel the Earth's magnetic field during an experiment conducted in a zero magnetic field environment. The solenoid's specifications include a diameter of 1.0 m, a length of 4.0 m, and a total of 5000 turns of wire.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of Ampere's law to calculate the magnetic field in the solenoid and the corresponding current needed. There are attempts to derive the current using different values for the Earth's magnetic field, leading to questions about the correctness of the calculations and the appropriate values to use.
Some participants have provided calculations based on their interpretations of the problem, while others have raised questions about the values used for the Earth's magnetic field. There is an acknowledgment of the need for accurate information regarding the magnetic field strength, with some guidance offered on using the correct value from a textbook.
Participants are working under the assumption that the solenoid must produce a magnetic field that exactly cancels the Earth's magnetic field, which is noted to be approximately 5 * 10^-5 T. There is uncertainty regarding the strength of the Earth's magnetic field and its impact on the calculations.
jlmessick88
A researcher would like to perform an experiment in zero magnetic field, which means that the field of the Earth must be cancelled. Suppose the experiment is done inside a solenoid of diameter 1.0 m, length 4.0 m, with a total of 5000 turns of wire. The solenoid is oriented to produce a field that opposes and exactly cancels the field of the earth. What current is needed in the solenoid’s wires?
∑B ∆length = (µ0)I
B = 5 * 10^-5 T
length = 4 m
radius = 0.5 m
i = [4*(5*10^-5)]/(5000*2*pie*0.5)
i = 1.27*10^-8
have i done this correctly at all??
using Ampere's law the magnetic field ina solenoid will be given by
B= magnetic permeability x current i x number of turns N / length L
and for cancelling Earth's magnetic field, the current needed is
i = B x L / N x magnetic permeability
= 0.4x10^-4 x 4 / 5000x 4 pi x 10^-7 = 2.55 x 10^-2 Amp
= 25.5 milli amp.
Or is this correct??
That would look correct but I don't know the strength of Earth's magnetic field off-hand
my book says that the Earth's magnetic field strenght is 5 *10^-5...so would i use that instead of the .4 x 10^-4??
Yes.
10K
  • · Replies 23 ·
