How long does it take the ray to traverse this path?
  • Thread starter Thread starter mba444
    Path Ray
The problem involves a light ray entering the atmosphere of a planet and descending to the surface, with varying indices of refraction. The original poster seeks to determine the time it takes for the ray to traverse this path and also how long it would take in a vacuum.
  • The original poster attempts to calculate the time taken for the light ray using the change in refractive index and speed of light, but expresses uncertainty about their method. Other participants suggest different approaches to calculate the velocity in the medium and question the need for calculus due to the uniform change in refractive index.
Participants are exploring various methods to approach the problem, with some providing equations related to the velocity of light in different media. There is a lack of consensus on the best method to apply, and the original poster is seeking clarification on the second part of the question.
The original poster mentions uncertainty regarding the requirements for the second part of the question, indicating potential gaps in understanding the problem setup.
mba444
A light ray enters the atmosphere of a
planet where it descends to the surface
15.2 km below. The index of refraction where
the light enters the atmosphere is 1.2 and it
increases uniformly to the surface where it has
a value of 1.55.
I) How long does it take the ray to traverse this path? Answer in units of s.
II) How long would it take to cover the same distance in a vacuum? Answer in units of s.
speed of light= 2.99*10^8
delta V = C/(delta N)
delta V= delta X / delta t
For Question I what i did is that
delta N = N2-N1= 1.55-1.2= 0.35
delta V = (2.99*10^8)/(0.35) = 8.54*10^8 m/s
delta t = 15.2*10^3/8.54*10^8= 1.779*10^-5sec
but I am not sure if my way is correct can someone please check and tell me if I am going wrong somewhere
and for II) i didnt understand what is needed therefore i didnt know how to attempt at a solution
need your help and thanks in advance
V1 = C/N1
V2 = C/N2
delta V = C( 1/N1 - 1/N2)
i didnt understand
Velocity in the medium = velocity of light in vacuum/refractive index of the medium.
So Δv = C/N1 - C/N2
is this a calculus-based course? because i think you would need to use calculus in a situation where the refractive index changes uniformly. as for the second part, it's much easier than you're making it. after all, the index of refraction is relative to the vacuum. for instance, in a piece of glass with index n=1.5, light travels 1.5 times more quickly in a vacuum than it does in the glass.
  • · Replies 21 ·
16K
