Calculate angle of reflection.
by EinsteinKid
Tags: angle, reflection
EinsteinKid
EinsteinKid is offline
#1
Jul14-09, 04:03 PM
P: 2
Hello everyone, I am new here to the physics forums. So for my first post I need some help on this problem from my homework. Here we go:
A laser beam of wavelength 632.8 nm shines at normal incidence upon the reflective side of a compact disc. The tracks of tiny pits in which information is coded onto the CD are the 160 um apart. For what angle of reflection will the intensity of light be maximum?
Any help is great appreciate, thank you.
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
cepheid
cepheid is offline
#2
Jul14-09, 04:09 PM
Emeritus
Sci Advisor
PF Gold
cepheid's Avatar
P: 5,198
Hi EinsteinKid,
Welcome to PF!
http://www.physicsforums.com/showthread.php?t=89899
http://www.physicsforums.com/showthread.php?t=5374
This should be posted in the Homework Help Section (a moderator will probably move it for you), and posted using the template for homework help threads (which requires you to state the problem, relevant equations, and most importantly, *your attempt* at a solution so far). If you read the forum rules I linked to, you'll see that we don't do your homework for you. We will, however, help set you in the right direction if you aren't getting anywhere with your attempt.
EinsteinKid
#3
Jul14-09, 04:14 PM
P: 2
Quote Quote by cepheid View Post
Hi EinsteinKid,
Welcome to PF!
cepheid
sorry about that, I was reading the rules, I knew right away I messed up. THanks for the heads up
Doc Al
Doc Al is online now
#4
Jul14-09, 04:19 PM
Mentor
Doc Al's Avatar
P: 40,880
Please repost your problem--along with your work so far--in the correct forum (such as Intro Physics).
Also, please review our posting rules, which are linked at the top of every page, and the Homework Help FAQ.
Welcome to PF!
Register to reply
Related Discussions
Angle of Incidence and Reflection. General Physics 9
Angle of reflection with moving mirror, SR Advanced Physics Homework 5
Angle of Incidence for Internal Reflection Introductory Physics Homework 7
Angle of reflection equation? Introductory Physics Homework 9
Angle of incidence and reflection of a parabola? Calculus 2
