What Gas is Produced from H2O+HCL?
  • Thread starter Thread starter wasteofo2
    Gas
The discussion revolves around the gas produced when mixing water with hydrochloric acid (HCl) in a pool maintenance context. Participants explore the nature of the gas observed, potential reactions, and safety concerns related to handling hydrochloric acid.
  • Experimental/applied
  • Some participants suggest that the observed gas may be steam resulting from the dilution of HCl in water, while others propose it could be HCl gas escaping from the solution.
  • One participant notes that HCl dissociates into ions in water and does not produce gas directly, but acknowledges that reactions with metals can produce hydrogen gas.
  • Another participant mentions that HCl is a gas that can fume when dissolved in water, particularly in concentrated solutions.
  • Concerns are raised about the potential for other reactions occurring, possibly involving impurities or contaminants in the vat.
  • There is mention of the exothermic nature of diluting HCl, suggesting that the gas could be a mixture of HCl gas and water vapor.
Participants express differing views on the nature of the gas produced, with no consensus on whether it is solely steam, HCl gas, or a combination of gases resulting from other reactions. The discussion remains unresolved regarding the exact composition of the gas and the implications for safety.
Participants highlight the importance of considering the concentration of HCl and the presence of impurities, which may influence the reactions and gases produced. The discussion does not resolve the specific conditions under which the gas was observed.
wasteofo2
I work at a pool, and to keep the pH constant (chlorine is a base I suppose), there is a vat of water and hydrochloric acid which is pumped into the pool when the pH reaches a certain level of basicness. Anyway, it ran out today and it's the lifeguard's (my) responsibility to re-fill the tank with water and add hydrochloric acid to it. When I did this, I noticed that there was a steam coming from the vat. I was careful to hold my breath and not inhale any of it, and was curious what exactly it was, and if I should be supplied with some sort of gas-mask for this task.
Chemistry news on Phys.org
I don't think it makes a gas
H2O + HCl -> H+(aq) + Cl-(aq)
the hydrochloric acid just breaks up into ions, perhaps the gas really was steam, or possible resulting from another reaction inside the container, if you put a metal into hydrochloric acid, then it makes hydrogen gas and a salt, for example:
6HCl(aq) + 2Al(s) -> 3H2(g) + 2AlCl3(s)
hydrochloric acid + aluminum makes hydrogen gas and aluminum chloride
did you by chance happen to smell much of it?
Didn't smell any of it, out of fear it was chlorine gas or anything else that might be dangerous. The vat is plastic, and there was actually a dead insect in there, so one of those could have cuase the reaction possibly?
I doubt that the insect caused it.
even if you try not to smell something, like chlorine gas, it is still pretty hard not to smell it (it just sneaks it's way in), So I am thinking that if that is what it was, you would have smelled some of it.
was the gas coming out since you had first oppened the container, or only after you added the HCl? Have you ever experienced this before?
was the inside of the container hot, like an oven, could it just be evaporating some water?
The container was near empty when I opened it. I filled it with mostly water, and then added the HCl, I felt no heat from the container, the gas was white and rose very slowly, very much like water vapor. Again, I did not inhale, and noticed no odor.
HCl is a gas.
The stuff you used was muriatic acid I reckon, and they dissolve the gas in water.
What you saw was probably the HCl gas coming out from the solution. It fumes quite readily, especially after being contained inside a bottle for a set amount of time.
thunderfvck said:
HCl is a gas.
You need to have a very concentrated solution of HCl to see fumes. If the fumes were coming out of the HCl bottle, then thunderfvck is right. You are seeing HCl fumes. HCl is a slightly heavy gas (20% heavier than air), hence will not rise very fast. Also, it is a very corrosive acid and you don't want to be inhaling it. And be careful not to get it on your skin (wear gloves while handling). Check out the MSDS for HCl :
http://www.chem.tamu.edu/class/majors/msdsfiles/msdshcl.htm
If had added the acid solution to the alkaline I suppose reactions can occur which produce gases. For the most part, the gas was probably not HCl, anyone who has taken a lab course knows that HCl is a fuming liquid at room temperature and has a pungent odor, in contrast with what you said to be an odorless gas. It could have also reacted with impurities, this would expain the transient nature of the reaction you observed.
Online help with chemistry
http://groups.msn.com/GeneralChemistryHomework
It's also an exothermic reaction when you dilute HCl in water. My guess is it is some mixture of HCl (g) and water vapor.
24K
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 19 ·
11K
