Thread Closed
Miller index
Share Thread Thread Tools
Jun25-04, 02:01 AM   #1
Miller index
How we can calculate the Miller's index?
Thanks
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> Nanocrystals grow from liquid interface
>> New insights into how materials transfer heat could lead to improved electronics
Jun25-04, 01:08 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
http://onsager.bd.psu.edu/~jircitano/Miller.html
Jun30-04, 03:51 AM   #3
Yes i know about this, but i want ask u: what is the different between (102) et (012)? how to obtain(102) ?are there the methode to take this?Thank.
Jun30-04, 05:24 PM   #4
Recognitions:
Homework Helper Homework Help
Miller index
It's a convention. There is something about the four different delimiters: (),[],{}, and <>. When you surround the numbers with (), then (102) is the same as (012), unless you are worried about the orientation. For the orientation's sake, you should have a right-handed permutation (conventionally) or you should specify.
Jun30-04, 09:30 PM   #5
Recognitions:
If I remember the conventions correctly {xyz} refers to the familiy of planes with indices x,y,z. (x,y,z) refers to the specific plane.
Similarly [] and <> are for a line and a family of lines.
If you have a polycrystalline material, you don't really care about a specific plane, and only wish to specify the family (this specifies plane spacing, and hence diffraction angles, etc.). However, for a single crystal, the specific plane within a family could be important.
Jul1-04, 04:51 AM   #6
Quote by turin
So we can not calculate directly all this index?
In Bragg relation, if we know the angle incident, so we can calculat the distance inter_reticular, suppose that we know about wave lenght.From heer, do we can calculate the Miller index? if yes , how to do?
Thank for respons.
Jul1-04, 08:59 AM   #7
Recognitions:
I don't think you can do it at just one orientation. I think you have to probe (in principle) all angles of incidence from all directions to extract the orientation of the lattice in the laboratory. I haven't really worked formally with this stuff in the lab though.
Jul1-04, 09:03 AM   #8
Recognitions:
From the Bragg angle and the wavelength, you can get the inter-plane spacing, d.
[tex]n \lambda = 2d sin \theta~~ [/tex]
From the value of d, and the knowledge of the material (which tells you the lattice parameter, a) you can calculate the Miller Indices of the reflecting planes
[tex] d = \frac {a} {\sqrt{h^2+k^2+l^2}} [/tex]
Jul2-04, 08:35 AM   #9
Quote by Gokul43201
Ok i agree with u about this, but for exemple, the value of
{h^2+k^2+l^2} is equal to 8 so we will get the Miller index for example:
h=2; k=2 and l=0 or we write (220). if we want get (202) or (022) , are there possible?
Thank for your response.
Jul2-04, 06:54 PM   #10
Recognitions:
(020) and (022) are different planes of the same family
{220} = (220),(202),(022),(-220),(2-20),(-202),(20-2),(-2-20),(-20-2),(-20-2) etc.....
Jul2-04, 11:10 PM   #11
Recognitions:
Like I said before, the plane spacing only specifies the family, not a particular plane. So you should really be talking about the family of planes {220} which Dr Transport has listed above.
PS : Dr Transport - there's an error in your first line. Perhaps you meant to write (220) instead of (020) ?
Jul4-04, 10:32 AM   #12
Recognitions:
correct, (220) instead of (020)...........
Jul5-04, 09:46 AM   #13
Quote by Dr Transport
yes i understand here, but how to obtain:
{220} = (220),(202),(022),(-220),(2-20),(-202),(20-2),(-2-20),(-20-2),(-20-2) etc.?with the calculat?
Jul5-04, 12:34 PM   #14
Recognitions:
each has an equivalent distance d, in a cubic material all of these are the same plane. In a tetragonal material, there would not be as many equivalent planes because different axes are not the same.
Jul9-04, 06:56 AM   #15
if i have: (degré) a (pm)
11,6 665,4
13,5 661,8
19,6 651,3
23,9 660,5
28,4 649,7
and wave lengh = 154,5pm .
How we can calculat the Miller index?
Thak for the friend who will want give me the respons.
Jul9-04, 09:51 AM   #16
Recognitions:
Could you clarify what those numbers are, and what is pm ? Is it picometer (10^-12 m) ?
Jul12-04, 05:24 AM   #17
Quote by Petit Einstein
Now I have one question to ask u:
for example, I have the value of Bragg angle and of latice constant:
(degré) a (pm)
11,6 665,4
13,5 661,8
19,6 651,3
23,9 660,5
28,4 649,7
and i have the vawe lengh used = 154,5pm.
How can we calculat the Miller index?
Thank for the response to me.
Thread Closed
Thread Tools
Similar Threads for: Miller index
Thread Forum Replies
Miller indices Atomic, Solid State, Comp. Physics 5
Miller Indices Advanced Physics Homework 0
Miller Index Question Introductory Physics Homework 6
miller indices question Atomic, Solid State, Comp. Physics 6
Miller indices Introductory Physics Homework 3
