How to Restrict Internet Access
  • Thread starter Thread starter thrill3rnit3
    Internet
The discussion revolves around methods to restrict internet access to a limited number of websites, particularly in the context of parental controls for a younger sibling. Participants explore various technical solutions, including software options and router settings.
  • One participant inquires about restricting internet access to selected websites without purchasing software.
  • Another suggests using a firewall or proxy, particularly at the network gateway level.
  • A participant expresses uncertainty about implementing these solutions and specifies the need to restrict access for a younger sibling.
  • OpenDNS is proposed as a potential solution for filtering, with a note that it may not allow blocking all but a few sites but can filter categories.
  • There is a suggestion to set up whitelisting directly on the router, as this may be more effective than PC-level restrictions.
  • One participant mentions forgetting their router login details, which could complicate access to the router settings.
  • Concerns about circumvention are raised, but one participant expresses confidence that their younger sibling would not be able to bypass the restrictions.
  • A later reply notes that routers have reset buttons that can restore default settings, including passwords.
Participants present multiple approaches to the problem, with no consensus on a single solution. There are differing opinions on the effectiveness of various methods, and some uncertainty remains regarding the implementation of suggested solutions.
Limitations include the participant's lack of access to router settings due to forgotten login details and the uncertainty about the capabilities of OpenDNS in achieving the desired level of restriction.
thrill3rnit3
Is there anyway that I can restrict internet access to a few selected websites without having to purchase software to do the job? If so, how?
Any help would be appreciated. Thanks.
Computer science news on Phys.org
You could use a firewall or a proxy.
If you are in a network then you should install the firewall (or a proxy) in the gateway.
I'm not really sure how to do that :-p
I want to restrict the internet access so my little brother can only access a few approved websites.
You can install OpenDNS and use its filtering. I'm not sure if you can block all but a few sites, but you can block many categories. What you are trying to do is known as a 'whitelist'.
http://blogs.howtogeek.com/mysticge...-your-kids-online-with-any-os-using-open-dns/
Edit: What kind of router do you have? You may be able to set up whitelisting directly on there. Ideally you want to do something on the router level, as anything done on the PC could be circumvented pretty easy.
I completely forgot my router login details so I might have some problems accessing the router home page.
I'm not really worried about it being circumvented, because it's just for my little brother and I doubt that he'll be able to do it cause he's like 7.
I'll look into this OpenDNS thing, thank you.
Routers have reset buttons on them which will reset all the settings including the password.
  • · Replies 24 ·
  • · Replies 27 ·
10K
