2 inputs to one headset control
  • Thread starter Thread starter noagname
    Control
The discussion revolves around the feasibility of connecting two audio inputs—an intercom system and an iPod—into a single headset for use in an airplane. Participants explore potential electronic solutions, specifically using PNP transistors, while considering safety implications and existing equipment standards.
  • One participant proposes using two PNP transistors to allow the intercom audio to override the iPod audio when active.
  • Another participant suggests a safer alternative of separating the audio sources into different ears to avoid missing important warnings.
  • A participant questions the effectiveness of the proposed transistor circuit and raises concerns about standard audio channel precedence in aviation headsets.
  • There is mention of existing FAA/TSO approved equipment that could achieve the desired functionality, emphasizing safety.
  • A participant expresses uncertainty about the concept of audio channels in the context of their headset setup.
  • Some participants indicate a reluctance to assist further due to safety concerns associated with the proposed modifications.
Participants express differing views on the safety and practicality of the proposed solution, with no consensus on whether the suggested circuit would work effectively. Some prioritize safety and existing standards, while others focus on the technical feasibility of the idea.
There are unresolved questions regarding the standard operation of airplane headset channels and the implications of modifying equipment without regulatory approval.
noagname
I was wondering if I had two inputs going to my headphones, one being the intercom on my airplane and the other being an ipod. Could I put two pnp transistors with collector and emitter on the ipod connections and the base connect to the intercom. So when audio comes threw the intercom the ipod sound drops.
Seems safer to put the plane audio in your left ear, and the music in your right ear. Wouldn't want to miss a warning on the Guard channel just because the switch-over circuit wasn't working one day, eh?
well if I forget about the danger will the idea still work by using pnp transistors
You're a pilot? :rolleyes:
And no, I don't think the simple circuit you describe will do what you want to do. What is the standard for airplane headset channels? I would think that radio traffic already has precedence over intercom traffic... is that the way your headset works currently?
Interestinglyalthough there is an application process in place to obtain TSO approval for flight communications equipment, there is no law or regulation in effect to prohibit one from using equipment without such approval, including pilot-modified equipment.
http://answers.google.com/answers/threadview/id/542619.html
Nevertheless, in the interest of safety, I recommend you look into existing FAA/TSO approved equipment which does what you want.
yes I am a pilot, and I'm not sure what you mean by channels, I'm just using the jack that I connect my headset. and before I posted I saw devices that do what I'm asking but I don't want to pay the money.
Well, if you don't feel like being safe, I don't feel like helping you.
I can't speak for anyone else here.
I think I'm just need to stop this thread. How would I do it
Happy to help. Closing the thread, I mean.
  • · Replies 37 ·
  • · Replies 18 ·
