Current-Can someone solve, please?
  • Thread starter Thread starter mar7pau
The discussion revolves around calculating the magnetic field and magnetic force at specific points due to two long parallel wires carrying equal currents of 10.0A in opposite directions, separated by 1.00mm. The magnetic field at Points A, B, and C, all located 0.50mm from the wires, must be determined using the formula for the magnetic field of a long straight wire. Additionally, the magnetic force on a proton moving at 3.40 x 106 m/s to the left needs to be calculated at these points.
  • Understanding of Ampère's Law for magnetic fields around long straight wires
  • Knowledge of vector addition for calculating resultant magnetic fields
  • Familiarity with the Lorentz force equation for calculating magnetic force on charged particles
  • Basic principles of electromagnetism, particularly regarding current-carrying conductors
  • Study the formula for the magnetic field around a long straight wire, specifically B = (μ0 * I) / (2π * r)
  • Learn about vector addition techniques to combine magnetic fields from multiple sources
  • Explore the Lorentz force equation, F = q(v x B), to understand the force on moving charges in a magnetic field
  • Investigate the right-hand rule for determining the direction of magnetic fields and forces
Students studying electromagnetism, physics educators, and anyone involved in solving problems related to magnetic fields and forces in electrical engineering contexts.
mar7pau
Current---Can someone solve, please?
Two long straight parallel wires separated by 1.00mm carrying currents in opposite directions with current equaling 10.0A each. Find the magnitude and direction of the magnetic field at Point A which = 0.50mm, Point B = 0.50mm, and Point C=0.50mm and write the directions of each. At each of these points, also find the magnitude and direction of the magnetic force on a proton, which is moving to the left at speed of 3.40 x 10^6 m/s? I would really appreciate your help on this one. Thanks
Not sure
Not sure
This is a bit confusing. point A,B and C are all the same?
First off what is the formula for the magnetic field of a long wire?
Secondly what does the magnetic field of a long wire look like?
Thirdly consider both wires separately, put yourself in let's say point A and find the direction of the magnetic field of wire 1 in point A. Now do the same for wire 2. Now add them together vectorially
ps. Not being sure implies that you have at least some sort of an idea. Make sure you show us your work!
