Force applied to simple hand pump and resulting PSI
The discussion focuses on calculating the air pressure generated by a simple hand pump, akin to a bicycle pump, when a force is applied to its handle. The key formula established is that pressure (PSI) is derived from the force exerted divided by the cross-sectional area of the piston. Additionally, the impact of friction between the O-ring and the inner wall of the pump is acknowledged, although the primary calculation can be simplified for rough estimates. Understanding these principles allows for better predictions of pump performance.
  • Basic understanding of pressure calculations (Pressure = Force/Area)
  • Familiarity with the mechanics of hand pumps
  • Knowledge of friction and its effects on mechanical systems
  • Concept of cross-sectional area in cylindrical objects
  • Research the effects of friction on pneumatic systems
  • Learn about the mechanics of bicycle pumps and their design
  • Explore advanced pressure calculation methods for varying conditions
  • Investigate materials used for O-rings and their impact on performance
Engineers, mechanics, and hobbyists interested in fluid dynamics, pneumatic systems, and the design of hand-operated pumps.
fred_1985
I hope I am asking this in the right forum.
Lets say you have a simple hand pump, similar to a bicycle pump, and you exert X amount of force on the handle. How do you calculate the resulting air pressure it creates out of the small valve at the end?
Obviously friction between the O-ring and inner wall of the pump is going to come into play, but a rough estimate would do.
Thanks.
Pressure is force divided by area. Force on the handle, cross sectional area of the piston.
  • · Replies 36 ·
  • · Replies 19 ·
