Thread Closed
[Numerical] System of first order ordinary diff equations with given asymptotic
Share Thread Thread Tools
Jul29-09, 03:44 AM   #1
ala
I have system of first order ordinary diff equations, indipendent variable is x cordinate. I know asymptotic solution in left and right region (i.e. when x->-infinity or x->infinity, e.g. when abs(x)>1000), it's const plus exponentially falling function. I want to find numerical solution in middle region, witch will have given asymptotic in left and right region.
If I give initial value at left (i.e. at x=-1000) numerical solution blow up at right (I also have exponentially growing functions on right).
How to do this?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jul29-09, 12:58 PM   #2
Okay, bellow is my attempt:
Let:
[tex]y(x)=c(1-w(x)exp(-kx))[/tex]
Then
[tex]
w(x)=(1-y/c)exp(kt)[/tex]
[tex]
\dot{w}=-\frac{\dot{y}}{c}exp(-kx)+k \ (1-y/c)exp(-kx)
[/tex]
Now time to make some substitutions
[tex]
\dot{w}=-\frac{f(y)}{c}exp(kt)+k \ (1-\left(c(1-w \ exp(-kx)) \right)/c)exp(kt)[/tex]
[tex]=-\frac{f(y)}{c}exp(kx)-w \ \left(1-\frac{k}{c}\right)exp(kx)+k \ w \ [/tex]
where [tex]y[/tex] is given above as:
[tex]y=c (1- w \ exp(-kx))[/tex]
and [tex]f(y)[/tex] is the original differential equation.
edit: The above only seems useful if [tex]\frac{1}{x}[/tex] is much bigger then [tex]k[/tex].
Jul30-09, 01:07 AM   #3
ala
For that x, I have asymptotic solution. I want to find numerical solution in the middle, but don't know how. (I don't have 1 ODE, I have system of ODE)
Thread Closed
Tags
numerical diff
Thread Tools
Similar Threads for: [Numerical] System of first order ordinary diff equations with given asymptotic
Thread Forum Replies
2nd order diff equations Calculus & Beyond Homework 4
Conversion of System of Eq's to 2nd Order Diff Eq Differential Equations 4
power series to solve 2nd order ordinary differential equations Calculus & Beyond Homework 3
asymptotic stability of a system ( ordinary DE) Calculus & Beyond Homework 3
Numerical Solution of Ordinary Differential Equations Advanced Physics Learning Materials 0
