Find the maximum bending moment
The discussion revolves around determining the maximum bending moment in a simply supported beam subjected to a uniformly distributed load. Participants are examining the expression for bending moment and its derivative to identify critical points.
  • Participants are attempting to differentiate the bending moment equation to find where the maximum occurs. Questions about the correctness of differentiation steps and signs are raised.
The discussion is active, with participants providing feedback on each other's differentiation attempts. There is an ongoing exploration of the mathematical expressions involved, but no consensus has been reached on the correctness of the calculations.
Participants note that an attempt must be made before receiving further assistance, indicating a collaborative approach to problem-solving within the constraints of homework guidelines.
SteveMckenna
The bending moment, M, at position x meters from the end of a simply supported beam of length l meters carrying a uniformly distributed load of wkN m^-1 is given by:
M = w/2 l (l-x) - w/2 (l-x)^2
Show, using the above expression, that the maximum bending moment occurs at the mid-point of the beam and determine its value in terms of w and l.
I know that the max bending moment will occur at the root of the equation: d/dx M(x) = 0
Sounds good to me. Go for it!
SteveMckenna said:
You need to make some sort of attempt before anyone here will help you out. The function you're working can be differentiated fairly easily.
I believe that dM/dx = wl/2 - w(l-x) thus far!
Is this correct before I continue?
Your signs are wrong. For example, d/dx(w/2 * l(l - x)) = -w/2 * l
  • · Replies 30 ·
10K
10K
