Optimizing Integration: Sketching vs. Graphing for Type I, II, and III Problems
  • Context: Undergrad
  • Thread starter Thread starter mathrocks
The discussion revolves around the methods of optimizing integration for finding volumes or areas using double and triple integrals, specifically focusing on the identification of type I, II, and III problems. Participants explore the necessity of sketching versus graphing to determine the appropriate setup for integration limits.
  • Exploratory, Technical explanation, Debate/contested
  • One participant expresses difficulty in sketching planes and questions whether graphing is the only method to identify type I, II, or III problems.
  • Another participant asks for clarification on what type I, II, and III refer to, indicating a lack of familiarity with the terminology.
  • A subsequent reply defines type I and type II problems in terms of the setup for limits of integration, providing specific mathematical expressions for each type.
  • Some participants suggest that the effectiveness of the setup depends on how well the problem is configured, with sketching being a helpful tool.
  • Another participant proposes that both type I and type II setups can be applied to the same region for a double integral, illustrating this with a specific example involving a triangular region and noting that sketching aids in visualizing the limiting functions.
There is no consensus on whether sketching or graphing is the superior method for identifying integration types, and multiple viewpoints on the necessity and effectiveness of each method are presented.
Participants have not fully defined type III problems, and there are unresolved aspects regarding the best practices for setting up integration limits. The discussion reflects varying levels of familiarity with the concepts involved.
Readers interested in integration techniques, particularly in the context of calculus and mathematical problem-solving, may find this discussion relevant.
mathrocks
If you want to find volume or area using double/triple integration, is graphing the (r) and (d) the only way to see if it is a type I, II, or III problem? I'm not really good at sketching planes so I'm having great difficulty finding the answer. But when it is already setup I can do it easily.
What are type I, II, III? never heard of that before.
They are just names for how we setup the limits of integration. A type one for double integration is when D={(x,y)| a<=x<=b, g1(x)<=y<=g2(x)}
Type II is D={(x,y)| c <= x <= d, h1(y) <= x <= h2(y)}
that depend upon how well u set up the problem, but skecthing helps
Couldn't you choose? For example, for a double integral, where the region to integrate over is the triangle with vertices (0,0), (2,0), (0,1), the region could be set with:
D = {x,y : 0 <= y <= -x/2 + 1 , 0 <= x <= 2} (type 1)
or:
D = {x,y : 0 <= x = 2y + 2 , 0 <= y <= 1} (type 2).
But then of course to see the limiting function for either of these, sketching helps.
  • · Replies 18 ·
  • · Replies 24 ·
  • · Replies 33 ·
