How Do You Calculate the E-Field of a Semi-Circle with a Uniformly Charged Line?
  • Thread starter Thread starter forty
    Circle E-field
The discussion revolves around calculating the electric field intensity at the center of a semi-circle formed by a uniformly charged line. Participants explore the implications of symmetry and the need for integration in their calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the necessity of using a single versus double integral for the problem, with some questioning how to express the charge elements and the angles involved. There are varying interpretations of the integration limits and the components of the electric field.
Several participants have offered insights into the integration process and the setup of the problem. There is ongoing clarification regarding the correct limits of integration and the components of the electric field that contribute to the total field at the center of the semi-circle.
Some participants express uncertainty about the orientation of the semi-circle and how it affects the definition of angles in their calculations. There are mentions of potential confusion regarding the integration of trigonometric functions over specific intervals.
forty
A line charge of uniform density [tex]\lambda[/tex] forms a semi-circle of radius R0. Determine the magnitude and direction of the electric field intensity at the center of the semi-circle.
I won't bother with uploading a picture I'm pretty sure you can picture this without.
My trouble with this is I'm unsure whether I need to do a double integral.
So here is my working.
E = (1/4[tex]\pi[/tex][tex]\epsilon[/tex]) q/r2 r
As the problem is symmetric only the cos([tex]\theta[/tex]) components add. So for a small piece of charge dq
Ei = (1/4[tex]\pi[/tex][tex]\epsilon[/tex]) dq/R02 cos([tex]\theta[/tex])
Now for this I have to sum up all the dq's but they are also all have a different angle. So do I do an integral for theta from -[tex]\pi[/tex]/2 to [tex]\pi[/tex]/2 ?
Anyway the answer I get is [tex]\lambda[/tex]/2[tex]\epsilon[/tex]R0
Any help with this would be greatly appreciated.
P.S. I'm new to latex.
First of all: no. Because it's a line of charge, i.e. a one-dimensional shape, you only need to do a single integral. (Think about it: if there were a double integral, what two variables would you integrate over?) If it were a two-dimensional surface, you might need to do a double integral; if it were a 3D volume, you might need a triple integral, etc.
Actually dE, not Ei:
[tex]\mathrm{d}\mathbd{E} = \frac{1}{4\pi\epsilon_0} \frac{\mathrm{d}q}{R_0^2}\cos\theta[/tex]
but anyway:
I think your answer is off by a factor of [itex]\pi[/itex] but the procedure is basically right.
When I say double integral I mean in respect to all the dq's and all the d[tex]\theta[/tex]'s.
When you sum up all the dq's to get the total charge isn't it [tex]\lambda[/tex][tex]\pi[/tex]Ro? And the integral of cos([tex]\theta[/tex]) from -pi/2 to pi/2 = 2?
So when I put it all together I get
E = (2/4[tex]\pi[/tex][tex]\epsilon[/tex])([tex]\lambda[/tex][tex]\pi[/tex]Ro/Ro2)
And it cancels to what I said?
For a small element dL, charge dq = λ*dL and dL = R*dθ.
So the electric field at the center dE = μο/4π*λR*cosθ*dθ/R^2
Or dE = μο/4π*λ*cosθ*dθ/R. Τake the integration from 0 to π.
isn't the integral of cos(θ)dθ from 0 to pi equal to 0?
There's no double integral. You need to express dq in terms of the variable θ: dq = λrdθ
isnt that integral 0? (isn't the integral of cos(θ)dθ from 0 to pi equal to 0?)
The integral should be from -π/2 to +π/2. (To avoid confusion, next time describe the orientation of the semicircle and how you define θ.)
I figured that after the first post I should of put up a picture. Thanks for clearing that up Doc Al (like always :) ). All makes sense now!
Thanks all!
Sorry. When you start with one end of the semicircle, the component of the field which add up is dEsinθ, rather dE*cosθ. Ιn that case the limit is 0 to pi.
  • · Replies 16 ·
  • · Replies 0 ·
