Electric Field of an Infinite Line of Charge: Analyzing the Rod
The discussion revolves around the electric field generated by an infinite line of charge and the properties of a conducting shell surrounding it. Participants are analyzing the implications of charge distribution and electric fields within and around conductors.
  • Participants explore the electric field inside a conducting shell and question the assumptions about charge distribution. There are attempts to derive formulas for electric field and surface charge density, along with discussions on the implications of electrostatic equilibrium.
Some participants have provided insights into the nature of electric fields in conductors and the behavior of charges. There is ongoing exploration of the differences between inner and outer surface charge densities, with multiple interpretations being discussed without a clear consensus.
Participants are navigating the complexities of charge distribution in conductors, with some expressing confusion over the definitions and implications of surface charge density. The discussion is influenced by feedback from an external source, which has prompted further questioning and clarification of concepts.
vorcil
http://img197.imageshack.us/img197/2942/assgn3q1.jpg
I took a good crack at this question, could somebody please check?
a)
I thought the shell could be modeled as a conductor with a hole in it,
as there is no electric flux inside a hole of a conductor and the charge of the shell is on the outside of the surface, there is no electric field, so the shell does not contribute to the electric field inside the shell
- this leaves the infinitely long rod!
I'm assuming the rod can be modeled as an infinite line of charge
and the formula for the electric field it creates is
(1/(4pi(epislon nought) ) ) * (2 lavender)/r
-n.b i would go through the proof of this formula but it's so long! and we all know it lol.
- the 2 cancels out 2pi
so the end formula is
lavender / 2pi * episolon nought * r
please check
b) the inner surface charge density? LOL Inner and surface made me automatically think the surface charge density of the inside of the rod is 0
but i know you'll probably want my proof
i know that it is a conducting rod, so all the charges get sent to the surface of the rod and there is no electric field/and flux inside SO my awnser is 0?
(can someone tell me why the charges get sent to the 0? I thought that it would be uniformly charged in a conductor, but at electrostatic equillibrium)
c)(will postsoon, i just need some time to do them)
I got it wrong, It is non-zero apparently?
this is mastering physic's response:
mastering physics said:
FeedbackRemember that the electric field inside a conductor must be zero. Thus, your gaussian surface must inclose a total charge of zero. However, we know that the rod has some finite charge, and thus the charge density on the inner surface must be none-zero.
c)
I know the charge on the shell is -2λ
the formula for length charge density is λ = Q/L
that means, Q(the charge over a length) = -2λ * L
we want the surface charge density so I'm lookin for Q/A
the the surface area of a rod = pi*r² * L
we want q/a,
(-2λ * L) / pi*r² * L
leaving me with
-2λ / pi*r²
still lookin for help with B) please
vorcil said:
c)
we want q/a,
leaving me with
-2λ / pi*r²
HOW DID I GET THIS WRONG?
mastering physics is bloody stupid
They are asking what the surface charge density is on the inner surface of the shell, NOT the rod. In fact the rod doesn't even have an inner surface.
so it's the same as the charge on the outside of the shell?
- is C) right?
I think i may have gone wrong for finding the surface charge density on the outside of the shell
it's 2*pi*r * L
so
Q / 2pi*r * L is what I'm looking for
Q = λ*L
-2λ*L = Q
-2λ / 2*pi*r = answer?
You're correct that you calculated the area of the shell incorrectly. However how does the calculation you're attempting now differentiate between the inner surface and the outer surface? Can you provide any arguments why exactly this pertains to the outer surface?
I can't provide any arguments,
I know the surface charge density on the inside of the shell is exactly the same as the surface charge density on the outside
i don't know how to differentiate between the field created outside the shell and inside the shell,
except that i know the field inside the shell should cancel out because of it being orientated in a circle
any other tips please?
Since the shell is a conductor the electric field inside the shell is indeed zero, as hinted by MP.
What are your arguments for thinking that the surface charge density is the same on both the inner an outer surface?
well it's a conducting shell
and also it doesn't state a thickness, only a length and radius from centre of the shell
This is not an argument. If the conducting shell would have had no charge on it what would the surface charge density be?
zero,
I ment that the cylindrical shell is made of a material that allows charge to be conducted through it?
It would not be zero. Could you explain to me what a conductor is?
something/a medium that allows electrons to flow freely?
things like metals are conductors
things like rubber are insulators
i know conductors allow electrons to flow freely because they have valence shell electrons (or the outer atoms aren't held in very well)
i see what you mean, i should've said electrons instead of charge
because positive charges (from protons) aren't able to flow through a conductor, but charge from electrons are (what about positrons?)
More precisely something that allows charges to flow freely. So if the conductor in your problem would have a zero line charge density, would you still think that the surface charge density would be zero as well? Explain your answer.
Hint: What happens to the charges if you put a conductor in an electric field.
  • · Replies 22 ·
  • · Replies 18 ·
