Pressure at Altitude: Sea Level vs 14,000 ft
  • Context: Undergrad
  • Thread starter Thread starter seilerbird
    Altitude Pressure
The discussion revolves around the behavior of tire pressure when an RV tire inflated to 100 psi at sea level is taken to an altitude of 14,000 feet. Participants explore the implications of altitude on tire pressure, considering both theoretical and practical aspects.
  • Some participants note that absolute pressure does not depend on altitude, while gauge pressure, which is what is read on a gauge, does change due to external atmospheric pressure differences.
  • There is a suggestion that in a real tire, the outside pressure at altitude would be lower, leading to a decrease in gauge pressure readings despite the internal pressure remaining constant initially.
  • One participant argues that the tire's rubber material would allow for slight expansion, potentially leading to a decrease in internal pressure relative to the outside pressure.
  • Another participant emphasizes that while the absolute pressure may decrease slightly, the relative pressure compared to ambient conditions would still be above 100 psi, indicating increased strain on the tire.
  • Some participants express skepticism about claims that there would be no change in tire pressure, arguing that the pliability of rubber means external pressure does influence internal pressure.
  • A later reply confirms that while the absolute pressure may decrease, the gauge pressure would read the same, indicating a nuanced understanding of the situation.
Participants do not reach a consensus; there are multiple competing views regarding the effects of altitude on tire pressure, with some arguing for no change and others asserting that changes do occur.
Limitations in the discussion include assumptions about the tire's material properties, the neglect of temperature effects, and the varying interpretations of gauge versus absolute pressure.
This discussion may be of interest to individuals exploring the physics of pressure in closed systems, particularly in relation to altitude effects, as well as those involved in automotive engineering or safety considerations for vehicles at high elevations.
seilerbird
If you inflate an RV tire to 100 psi at sea level and then drive to 14,000 feet, discounting temperature, will the tire pressure be the same, lower or higher?
It depends if this is a real tire or a 'homework' tire
In theory the absolute pressure doesn't depend on the altitude. If you put 100psi inside a container, that is 115psi absolute pressure inside and 15psi outside. The 100psi is called gauge pressure because it is what you would read on a gauge.
however in a real tire at altitude the outside pressure will be slightly lower and so there will be 115psi inside and perhaps 10psi outside. Although th epressure inside the tire hasn't changed a pressure gauge would read 105 (115-10) psi.
But in a real tire this change in the pressure difference would cause the tire to expand slightly (it's made of rubber) and the pressure inside would drop to slightly less than 100psi over the outside pressure, ie just less than 110psi absolute,.
Thanks for the reply. This is a real tire I am asking about, not a homework tire.
But in a real tire this change in the pressure difference would cause the tire to expand slightly (it's made of rubber) and the pressure inside would drop to slightly more than 100psi over the outside pressure, ie 110psi absolute,.
But wait, if the tire would expand wouldn't that be because the volume increases inside the tire causing the pressure inside the tire to decrease?
Sorry, typo - should have said "and the pressure inside would drop to slightly less than 100psi over outside"
Tires that run at 100 psi are pretty stiff and don't expand much. The absolute pressure would decrease slightly below 100 psi, but the relative pressure to ambient at 14,000 feet would be well above 100 psi, and there would be more strain on the tire.
Yes - wouldn't be much effect in the real world.
There is one telescope on Mauna Kea who insists on venting all the LN2 tanks on the basis that the safety valve is set for sea level pressure not 14,500ft. Don't know where their safety guy studied physics but I think it was a school that advertises on matchboxes.
Yes, I realize there would not be much effect in the real world. My question was based on a discussion on an RV forum. Some people were claiming there would be absolutely no change in the pressure of the tire since it is a closed system. I argued that the outside pressure would effect the internal pressure of the tire since rubber is plyable. I wanted to hear some opinions from some physics experts to see if the tire pressure would change or remain constant. The fact that the change would be small does not matter, only that the change would be there.
Then yes the tire absolute pressure will slightly decrease while the gauge pressure will read the same.
  • · Replies 53 ·
