Evaluating Triple Integral of G: xyz dV
The discussion focuses on evaluating the triple integral \(\int\int\int_{G} xyz dV\) over the region \(G\) defined by the boundaries \(x=1\), \(y=x\), \(y=0\), \(z=0\), and \(z=2\). The approach involves first treating two variables as constants and integrating over the remaining variable. Specifically, the integral is evaluated in the triangular region defined by \(0 \leq x \leq 1\) and \(0 \leq y \leq x\), followed by integrating the result with respect to \(z\) from 0 to 2. The final computed value of the integral is \(1/3\).
  • Understanding of triple integrals in multivariable calculus
  • Familiarity with the concept of changing the order of integration
  • Knowledge of evaluating integrals over triangular regions
  • Basic proficiency in handling variable limits in integrals
  • Study the method of changing triple integrals into single-variable integrals
  • Learn about evaluating integrals over different geometric regions
  • Explore the use of Jacobians in changing variables for multiple integrals
  • Practice solving triple integrals with varying limits and constraints
Students and professionals in mathematics, particularly those focusing on calculus and multivariable analysis, as well as educators teaching integral calculus concepts.
squenshl
Given the triple integral [tex]\int\int\int_{G}[/tex] xyz dV
Where G is the region bounded by x=1, y=x, y=0, z=0, z=2.
How do I evaluate it.
Please help.
First of all, is there any other constraint on x? I'll assume that x>=0.
Do you know how to change triple integrals into single-variable integrals?
The general idea is to first evaluate the integral while pretending that 2 of the variables are constant. Then you use that result to integrate over the other variables.
In this case it might be easiest to first evaluate the integral in the triangle 0<=x<=1 and
0<=y<=x while assuming that z is constant. Then integrate that result with z as a variable from 0 to 2. The triangle can be evaluated in a similar way. In other words:
[tex]I = \int^{2}_{0}(\int^{1}_{0}(\int^{1-x}_{0} xyz dy)dx)dz[/tex]
Cheers. I got an answer of 1/3
  • · Replies 27 ·
