What is the difference between laminar and turbulent flow?
The discussion focuses on the concepts of laminar and turbulent flow, exploring their definitions, characteristics, and visual representations. Participants seek to clarify these terms in simpler language, while addressing the complexities involved in distinguishing between the two types of flow.
  • Some participants describe laminar flow as a smooth flow where fluid particles follow steady streamlines, while turbulent flow is characterized by irregular motion and the presence of whirlpools.
  • One participant notes that there is no exact mathematical definition for laminar and turbulent flow, emphasizing that the transition between the two depends on various factors such as fluid velocity, geometry, and surface characteristics.
  • Another participant illustrates the concepts using the example of candle smoke, which transitions from a smooth upward flow to a turbulent state.
  • It is mentioned that in laminar flow, the volume flow rate remains constant along a tube-shaped region, whereas turbulence leads to scrambled particle velocities.
Participants express varying levels of understanding and interpretation of laminar and turbulent flow, with no consensus reached on a singular definition or explanation. The discussion remains open with multiple viewpoints presented.
Participants acknowledge the complexity of defining laminar and turbulent flow, highlighting that the transition between the two is influenced by several factors, and that the definitions may not be universally applicable.
101nancyma
Hi, guys, i tried to read the definitions of laminar and turbulent flowon some of the website, but had difficult time understanding them. I am wondering if you guys can explain the above terms in more plain words?
What specifically don't you understand?
Have you ever seen the flame and smoke of a candle flow straight and steady upwards, then suddenly get turbulent? That's laminar and turbulent flow.
I think there is no exact mathematical definition of laminar/turbulent flow.
Roughly speaking, laminar flow is such a flow, in which water particles follow streamlines that vary only slowly compared to the velocity of water. Turbulent flow is such a flow where fluid particles does not follow any steady streamlines (imagine smoke 0,5 m above the cigarette).
Practically, the fluid is in the laminar regime because its viscosity damps every instability of the flow. Instable flow with a lot of whirlpools require a lot of mechanical energy, which gets converted into heat by friction. Turbulent regime can start when the fluid velocity is so high that it can supply this energy. But this transition into instable flow depends on the geometry, kind of surface of the container and so on, so there is no simple sharp transition condition.
They often visualize laminar flow in a way that a group of streamlines (trajectories of fluid particles) trace out a tube-shaped region of space; that region has cross section area A; particles pass by that cross section with velocity v; the volume flow rate (cubic meters per second) is the product Av; if the fluid is incompressible (which liquids are) then Av is constant all along the tube-shaped region (the property known as continuity). You can say that only if you don't have turbulence. With turbulence the particle velocities would be all scrambled up.
Laminar flow follows a smooth path. The velocity of the fluid at any point is constant. Above certain critical speeds the flow becomes turbulent where it is irregular and characterised by small whirlpool regions.
Like russ has mentioned. if you look at a candle that has recently been blown out, you will notice the smoke particles are smooth and then at a certain height make whirlpool like formations.
  • · Replies 17 ·
17K
