Sound Physics: Generating Tones
  • Context: Undergrad
  • Thread starter Thread starter Ciemnl
    Physics Sound
The discussion revolves around generating the frequency in hertz for musical notes, specifically using middle A at 440Hz as a reference point. Participants explore various tuning systems, relationships between tones, and the implications of different scales on musical harmony.
  • One participant seeks a programmatic method to calculate the frequency of musical notes based on middle A at 440Hz.
  • Another participant provides a formula for calculating the frequency of any note using the ratio of 2^{\frac{1}{12}} and assigns numerical values to notes relative to A4.
  • A participant questions the notation in the formula, specifically the meaning of the dot indicating multiplication.
  • Discussion includes the concept of equal temperament as a tuning system, with a suggestion to explore other systems.
  • One participant elaborates on the relationships between tones, discussing consonance and dissonance through various mathematical relationships involving prime numbers and their multiples.
  • Another participant introduces the idea of natural scales, noting that they align harmonics perfectly but require retuning for different keys, contrasting this with the equal temperament scale.
Participants express differing views on tuning systems, with some advocating for equal temperament while others favor natural scales. The discussion remains unresolved regarding the optimal tuning approach for different musical contexts.
Participants mention the limitations of tuning systems, including the need for retuning instruments when switching keys and the subjective nature of perceiving differences in tuning among non-expert musicians.
This discussion may be of interest to musicians, music theorists, and those exploring the mathematical relationships in sound and music theory.
Ciemnl
Does anyone know how to generate the frequency in hertz of a note(middle C, F# ,G etc.) programatically assuming that middle A is 440Hz? Idealy you type in the note you wish to find the frequency of and it returns the frequency of it.
Thankyou!
The notes are separated by a ratio of [tex]2^{\frac{1}{12}}[/tex]. To get the frequency of any note if we know that A4=440hz, you have to use this formula:
[tex]f(n)=440 \cdot 2^{\frac{n-n_0}{12}}[/tex].
Where you need to assign a number 'n' to each note, n_0 being the number of the note A. To simplify the formula, you can choose n_0 to be 0.
Eg.: ..., n(G3#)=-1, n(A4)=0, n(A4#)=1, etc...
Thanks, I am guessing the dot after 440 means multiply
You may (or may not) find it interesting to investigate other tuning systems. The one GPPaille described is called "equal temperament".
The RELATIONSHIPS between the tones is interesting - consonance versus dissonance.
Go through the prime numbers:
1) 440*1=440. :- closest relation is itself
2) 440*2=880. :- A, same note one octave higher - very consonant
440/2=220. :- A, same note one octave lower - " "
3) 440*3=1320 :- E, 19 steps up - consonant
440*3/2=660 :- E, 7 steps up - "
440/3=146.67 :- D, 19 steps down - consonant
440/3*2=293.333 :- D, 7 steps down - "
5) 440*5=2200 :- Dflat, 28 steps higher
440*5/4=550 :- Dflat , 4 steps higher
there is more
. . . . and so on and so forth - tending towards dissonance as you progress through the primes
The chromatic scale uses the twelvth root of 2 ( 1.059463094) as has been already expressed in the above posts, and it is interesting to see the difference
Natural E, 7 steps up = 660
Chromatic E, 7 steps up = 659.25
In case anyone is interested, the "natural A scale" described by LeonStanley in post #5 is the optimum set of frequencies for playing music written in the key of A. All of the notes' harmonics line up with each other perfectly and it sounds nice.
However for music written in the key of C, the optimum scale would be the "natural C scale" based in a similar way on multiples of the frequency of C. And so on for all the other keys. The disadvantage of using the natural scales is that you have to retune your instrument every time you play music in a different key. The "equitempered scale" described by GPPaille in post #2 is a compromise that is sufficiently close to all of the natural scales that most people who aren't expert musicians arguably wouldn't notice the difference.
  • · Replies 58 ·
9K
