Finding the force on a particle inside the radius of the Earth
The discussion revolves around calculating the gravitational force on a particle located inside the Earth, specifically at a distance r from the center. The problem involves understanding the relationship between the mass of the Earth, its radius, and the gravitational force experienced by the particle, with a focus on deriving the force equation based on the mass contained within a sphere of radius r.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the need to express the mass of the Earth within radius r as a function of r. There are references to the Shell Theorem and the assumption of uniform density of the Earth. Some participants explore the implications of integrating to find the total force and question the necessity of certain mathematical steps. Others express confusion about the representation of spherical shells in diagrams related to the Shell Theorem.
The discussion is active, with participants providing hints and exploring various interpretations of the problem. Some guidance has been offered regarding the use of the Shell Theorem and the implications of assuming uniform density. There is a recognition of the complexity involved in visualizing the problem in three dimensions, and participants are engaging with the mathematical concepts without reaching a consensus on a single approach.
Participants are working under the assumption of uniform density for the Earth and are considering the implications of this assumption on the gravitational force calculations. There is also a discussion about the potential complexity introduced by visualizing the problem in three dimensions versus two dimensions.
bitrex
The mass of Earth is M, the radius of Earth is R. For a particle of mass m within the Earth at a distance r from the center of the earth, the gravitational force attracting m toward the center of the Earth is [tex]F_r = \frac{-GM_rm}{r^2}[/tex], where Mr is the mass of the Earth within a sphere of radius r. Show that [tex]F_r = \frac{-GMmr}{R^3}.[/tex]
I am completely blanking on how to go about this - I could really use a hint to get me started. :confused:
If the question is "what is the force as a function of r?", you will need Mr as a function of the radius.
Shell Theorem may help you simplify the problem a lot.
They are assuming a uniform density for the Earth here. What is the Earth's density, given M and R?
So if the density of the Earth is taken to be a constant, then we have [tex]\rho = \frac{M}{\frac{4}{3}\pi R^3}[/tex], and the mass of a thin shell is [tex]dm = 4\pi r^2 \rho[/tex]. So the total force towards the center experienced by a particle inside the Earth at a radius r would be:
[tex]Fr = - \frac{M}{\frac{4}{3}\pi R^3}\frac{4\pi Gm}{r^2}\int_{0}^{r}r^2 dr[/tex]. That gets me pretty close to the equation I'm going after! :approve:
You are very close. Actually I think in it's current form it will give you the correct answer, but for the wrong reasons.
But in any case, consider just the portion of your equation:
[tex]4\pi \int^{r}_{0}r^{2} dr[/tex]
what is this equal to?
https://www.physicsforums.com/latex_images/23/2310130-2.png
[/URL]
Looks good to me :smile: , but why stop there?
Sorry for the interjection.
But is this really that difficult?
If r is the radius at some place inside the Earth where the mass m lies, then all you need to know is the mass of a planet with the same density as the earth, only with a radius r. Doesnt all the other mass outside of r cancel itself out as far as force on the mass m? or what am I missing?
I believe I see what you're getting at: That integral is just the volume of the sphere with radius r, and the gravitational force exerted by a sphere with density [tex]\rho[/tex] and volume [tex]\frac{4}{3}\pi r^3[/tex] is just the volume times the density, plugged into [tex]\frac{GMm}{r^2}[/tex] with rho*v substituted for litte m. The integration wasn't really necessary.
This question did get me thinking about the shell theorem, though, and I have a further question about the explanation at http://en.wikipedia.org/wiki/Shell_theorem . Right at the top of the page it says "A solid, spherically symmetric body can be modeled as an infinite number of concentric, infinitesimally thin spherical shells." However, in the diagram directly below, the shaded area represented as dM doesn't look at all like a spherical shell to me - it looks more like a thin "slice" cut through the axis of the sphere, like a slice taken out of a sphere-shaped bread loaf. What's going on here?
Yeah, you're right. I was making the problem a lot more difficult than it really was.
The shaded portion is not the shell, but one thin infinitesimal slice from the shell. The outline of the shell itself is the black circle.
Well you know what. I was looking at it from a symmetry point of view from just drawing on a 2-d piece of paper. But now that I think about it in 3-d its not that intuitive. I think the math gets more complex. So if you have to prove that before you do the problem the easy way... (ie just assuming all the mass cancels out based on 2-d symmetry)... yikes. It may be more difficult. I am no expert. just learning along with you and everyone else.
You don't actually need the shell method to be incorporated into the problem.
I'm sure Fightfish brought it up so that you could see that the outer shells cancel out and all you are left with is what is under you.
But instead of doing concentric shells, just consider a single shell of arbitrary radius that is surrounding you. Then calculate the force of gravity that each point on the shell applies to you and you should find that the force is zero no matter where you are inside the shell, just as long as you are not on it or outside it. Then incorporating the shell method you can just say that ALL of the outside matter could just be thought of as individual shells which we now know each contributes a force of 0N.
18K
  • · Replies 28 ·
