What is the best power supply for a peltier-based water cooling unit?
The discussion revolves around selecting an appropriate power supply for a peltier-based water cooling unit. Participants explore various options for powering peltier plates, including computer power supplies, battery chargers, and other alternatives, while considering the implications of efficiency and safety in their designs.
  • Experimental/applied
  • One participant suggests using a computer power supply to convert AC to DC for the peltier plates but expresses uncertainty about the connection process.
  • Another participant points out that computer power supplies may have limited output capability at 12 volts, primarily designed for lower voltage logic chips.
  • Some participants propose using ready-made peltier food coolers that operate on 12V automobile supplies, suggesting that a battery charger could replace the power source.
  • Concerns are raised about the efficiency of using a battery charger compared to a steady DC source.
  • One participant mentions the importance of sealing the peltier cooler to prevent condensation when operating below the dew point and discusses potential sealing materials.
  • Another participant shares mixed experiences with using RTV for sealing and suggests thorough surface preparation for better adhesion.
  • There is a discussion about using Molex connectors from computer power supplies to power peltier plates, with a request for clarification on their implementation.
  • Some participants argue that high current at 12 volts may not be achievable with standard computer power supplies or wall warts, suggesting the need for dedicated 12V switchers.
  • Alternative suggestions include converting a PC power supply for high current 12 volts and using a car battery with a float charger for a more sustainable option.
  • A participant mentions TORR SEAL as a potential sealing solution for high vacuum applications.
Participants express differing opinions on the suitability of various power supply options, with no consensus on the best approach. There are multiple competing views regarding the efficiency and practicality of the proposed solutions.
Participants note limitations regarding the output capabilities of computer power supplies and the need for careful sealing to prevent condensation, but do not resolve these issues.
DoomDuck
Hi,
I'm new here so I apologize if my question isn't composed appropriately.
I’m currently designing water cooling unit, which is a component of a larger project, that utilizes peltier plates as a heat pump to displace the energy from the water. To cool the peltier plates themselves I want to employ heat sinks and CPU fans, as to prevent the plates from over heating and damaging themselves.
The problem I’m encountering with this system is finding the appropriate power supply. I know all the components consume DC power but I was hoping to be able to plug this into a standard US outlet. I lack the electrical skills to actually make an appropriate selection for this purpose, but I was thinking that I could use a computer Power Supply since that converts AC power to DC power but I’m unsure as how to connect the peltier coolers to those P-type connectors.
Any suggestions or ideas regarding this? I’ve listed the specifications of the peltier coolers below but I haven’t made a decision on heat sinks and cooling fans.
168 W Peltier Cooler 12V
At 50 C
Qmax = 120 W
Imax = 10.9 A
Vmax = 15.4
Thanks
Hello Double-D,
It sounds like a good time to visit Digikey.com. Type in power supplies and go from there. you should be looking at $100-$200.
The computer switchers have very little output capability at 12 volts. They're designed to supply the vast majority of their power to the logic chips (3.3 volts?).
Oh, one other thing. If your running your junction below the dew point, you need to seal it up to protect from condensate.
- Mike
You can buy fairly cheap ready-made peltier food coolers at your local department store or online. they run on 12V automobile supply, so you could replace that with a battery charger.
Fleem's got a good point about the food coolers - They're sealed, and already have a heat sink. The only difficulty I can see is getting to the cooling side without tearing up the seal. The two heat sinks are most likely sealed together, and machining down one heat sink without dis assembly would be a hassle.
I'd look for a better power supply though. I suspect you'll get much better efficiency from a steady DC source than a pulsating source like a battery charger.
And, just as a general safety rule when beginning to work with high frequency switching power supples (which frequently are not fullly isolated from the mains), is an isolation transformer for your work bench. Not needed in the final system, but a safety item during the 'open' design and construction phases.
I understand that it is pertinent to protect the peltier cooler from condensation if I am running it below the dew point, but how would you suggest I seal it. The reason I chose to use peltier coolers for this project specifically is due to the fact I already have some laying around, so I was hoping to employee those rather than purchasing new ones.
Double-D,
I've only had mixed results when attempting to make air-tight seals with RTV, but it seams to be the only game in town. I've seen military seals that used some tough, pink rubber, and then the everyday seals that they use for food coolers, which are a white rubber that's also tenacious.
I guess I would attempt to clean the surface very-very thoroughly and stick with RTV. I think I might even go so far as to go after the surface with some heat-sink compound (or better yet, a water-based polish) and a rag before hitting it with some lighter fluid and then IPA. The heat sink compound is pretty good at polishing. You just need to clean the grease out afterwards... That should help with the porosity and scratches.
http://www.overclock.net/faqs/112445-how-make-80-watt-peltier-beverage.html
I acctually found this link to an older forum post that addresses the creation of a peltier beverage cooler. I understand that he didn't appropriatly account for condensation from operating below the due point, but my attention was drawn to the power set up he created using Molex connectors. Outside of constructing a computer, I haven't encountered this use for Molex connectors, and I believe he used them so that a computers power supply could power the peltier plates. Is that inference correct? Could anyone elaborate on implementing molex connectors in this manner with "loose" wires?
Also what about using a wall wart? I'm disregarding efficiency.
If you're needing many amps at 12 volts, you're not going to get it from the 12 volt supply on a computer PC or a wall wart. You could get considerable current (10's of amps) at lower voltages (3.3 or 5) using computer supplies.
If you can run with lower voltages (lower temperature change), than the PC supply will work, otherwise you need something a little more dedicated - A 12V switcher
there are a few projects about, that show you how to convert to high current winding and power supply components of a standard PC power supply, to change the high current supply part from the 5Volts for the digital logic, to the 12Volt supply for just such a purpose.
look up "silicon chip" magazine or the like.
"converting PC power supply for high current 12 volts".
also if you need high current 12V, and it does not have to be super "clean", you can use a car battery and a bar battery float charger, then you can even claim "green" and put a solar panel on it.
TORR SEAL is a polymer high vacuum sealant.
  • · Replies 21 ·
10K
28K
