Why is Rabi frequency important in physics?
  • Context: Graduate
  • Thread starter Thread starter KFC
    Frequency
The discussion centers on the physical significance of Rabi frequency, particularly in the context of two-level systems in physics. Participants explore its definition, implications in quantum mechanics, and experimental measurement techniques.
  • One participant seeks clarification on why Rabi frequency is termed "frequency" from a physical perspective.
  • Another explains that Rabi frequency is associated with two-level systems and describes its role in coherent energy transfer between light fields and these systems.
  • Participants inquire about typical values for Rabi frequency, noting that it varies based on the specific system and conditions.
  • One participant emphasizes that the Rabi frequency is influenced by factors such as the dipole moment of the transition and the amplitude of the optical pulse used in experiments.
  • A detailed explanation is provided regarding the experimental setup for measuring Rabi oscillations, including the significance of pump pulse area and its relation to differential transmission measurements.
Participants express uncertainty regarding the typical values of Rabi frequency and its dependence on various factors, indicating that no consensus exists on a definitive answer.
The discussion highlights the complexity of determining Rabi frequency experimentally, as it is contingent on multiple variables including system characteristics and experimental conditions.
KFC
I am trying to find out the physical significance of Rabi frequency in wiki and some text, but it still hard for me to understand it. So what does Rabi "frequency" really refer to? From the point of physical view (not from dimension), why call it "frequency"?
The term Rabi frequency occurs in several branches of physics, but its most common occurrence is in the realm of two-level systems. So imagine some two-level system, which can be properly initialized (a two-level-atom, an electron state and a trion state inside a singly charged quantum dot or whatever).
Now you initialize the system in the upper state and drive the transition resonantly using a resonant laser pulse or something like that. Usually you will see just some random superposition of stimulated emission and some spontaneous emission. But if you are in the strong coupling regime - so the coupling strength is large compared to all mechanisms causing decoherence like spontaneous emission or nonradiative recombination- you will see some coherent energy transfer between the light field and the two-level system. If the two-level system is initially in the excited state, you will have stimulated emission, the system will go to the ground state, you will have stimulated absorption, the system will go to the excited state, you will have stimulated emission again and so on and so on. Therefore the occupation expectation values of the two levels will also oscillate periodically. The frequency of the periodic exchange of energy and of the oscillation of the occupation probabilities is the Rabi frequency.
So what's the typical value for Rabi frequency?
It can be anything; the typical frequency depends on what type of system it is.
This is diffivult to say. The exact value depends on the system, the dipole moment of the transition and (for optical transitions) the amplitude of your optical pulse. If you use a pump pulse with higher amplitude, the Rabi frequency will increase, too. This makes it very complicated to determine the frequency experimentally. So the common experimental way to show Rabi oscillations is to measure the time resolved differential transmission in a pump-probe-setup, where the fixed time delay between pump and probe pulse is longer than the pump pulse width, but shorter than the dephasing time.
If one now increases the pump pulse amplitude, the corresponding differential transmission shows oscillations depending on the pump pulse area. Here the pump puls area does not mean some spatial extent, but is measured in radians. So if there is no pump present, the system will not be in an excited state giving a pulse area of 0. Increasing the pump amplitude, at some point you will have a fully excited system at your chosen probe delay, indicating a pump pulse area of pi. Further increasing the pump amplitude will again deexcite the system at your chosen probe delay. So there will again be a minimum in the differential transmission at a pump pulse area of 2 pi. And so on and so on.
See for example Phys. Rev. Lett. 87, 133603 (2001) by Stievater et al. for a more detailed description of what pulse area is.
  • · Replies 0 ·
  • · Replies 78 ·
  • · Replies 26 ·
  • · Replies 16 ·
