Fundamental Theorem of Arithmetic Problem
The discussion revolves around a problem related to the Fundamental Theorem of Arithmetic, specifically focusing on the formal proof of the theorem as it pertains to prime factorization. Participants are exploring the requirements for constructing a proof and clarifying the implications of the problem statement.
  • One participant expresses confusion about how to begin a formal proof for the problem, seeking hints to get started.
  • Another participant suggests that the values t1, t2, etc., are greater than or equal to zero, which may help in addressing the problem.
  • There is a discussion about the process of combining prime factors from two numbers, with one participant illustrating this with an example of multiplying prime factorization.
  • A participant challenges the approach of multiplying exponents, emphasizing the need to represent numbers with the same bases of primes instead.
  • Some participants note that the problem requires formal proof, with one suggesting that the proof should state that the product of two numbers has a unique prime factorization.
  • Concerns are raised about the sufficiency of problem 3 in relation to problem 4, with some arguing that problem 3 only collects equal primes and does not address the introduction of zero exponents needed for problem 4.
  • Another participant mentions that while problem 3 can demonstrate unique factorization, it does not directly express one number in terms of the prime factors of another, which is necessary for the proof.
  • There is a suggestion that problem 4 may simply require applying the fact that p^0 equals 1, without needing to prove it.
  • One participant points out that the prime factorization must account for the possibility of zero exponents, which is specifically allowed in problem 4.
Participants exhibit a mix of agreement and disagreement regarding the relationship between problems 3 and 4, the requirements for a formal proof, and the interpretation of the problem statement. No consensus is reached on how to approach the proof or the sufficiency of the provided information.
Some participants express uncertainty about the specific requirements for a formal proof, and there are unresolved questions about how problem 3 relates to problem 4 in terms of prime factorization and the treatment of zero exponents.
Fisicks
Problem number 4 on the image has me stumped. I understand the problem (obviously not enough) and what its saying, I'm just having trouble putting it into a proof. Can i get a hint to get me started? Thanks
http://img40.imageshack.us/i/asdasdjql.jpg/"
I think you should pay attention to the fact t1 , t2, etc . are greater than OR EQUAL TO zero.
This should solve your purpose.
I think you mean g_i and h_i?
Fisicks, I don't know what problem you have. The basic idea is simple: sort the q_i and s_i in order and put them into one big list. When a number comes from both lists, add the exponents; otherwise take the exponent from where it came (e_i or f_i). Example:
(3^2 * 2^1) * (7^2 * 2^2 * 3^3) =
(2^1 * 3^2) * (2^2 * 3^3 * 7^2) =
2^(1+2) * 3^(2+3) * 7^2 =
2^3 * 3^5 * 7^2
greathouse why are you multiplying exponents, its just representing a and b to have the same bases of primes, and what i need help with is the proof part, not the what is the problem saying part.
Sorry, misread the problem. Your problem is easier -- just ignore the part about adding, and take missing primes' exponents to be 0.
yeah i get that part! i need to know how you would write a formal proof to show that, cause that's what the problem is asking.
Without knowing the requirements for your "formal" proof I couldn't possibly start. I don't imagine you mean what I mean when I say 'formal'.
i don't know what more you want, the question is posted right up there in that link lol. all i want to know is how to answer that question.
I think you are having a problem of not being able to see a forest when a thousand trees are right in front of you. It is formal to state that a*b is a number that according to problem 3 has a unique prime fractorization, the rest is a fairly simple exercise.
Yes, for a truly formal proof, see "Principia Mathematica". Not sure where the theorem in question is; probably in volume 2 or 3.
Dragonfall isn't it true that the only theorem needed is that provided by problem 3. I believe that problem 3 should be easy to give a formal proof. All the trees in problem 3 are those provided by "a" and "b" and how to obtain the forest that comprises them is simply to multiply "a" and "b". So what does problem three say about the product of "a" and "b"?
Problem 3 isn't enough, it just "collects" equal primes into single powers. In problem 4 you have to "split" the product by introducing powers of 0. A proof along the lines suggested by CRGreathouse is what the problem's asking for, I think.
You can use problem 3 to say that a*b has a unique factorization, but you won't be able to say that a can be expressed with the prime factors of b directly, which is required for problem 3 to apply.
I think all problem 4 was asking was to apply the fact that p^0 is equal to 1 to expand on the proof of problem 3. Call it an axiom or a proven fact or what ever, but I don't think problem 4 requires one to prove that p^0 is 1.
Not having seen the rest of the book, I don't know how problem 3 really relates to problem 4. But the fact is that to use the result of 3, you need to have the prime factorization. However, 1 isn't a prime, so you can't just use the fact that p^0=1.
You don't understand because problem 4 specifically allows zero as the exponent of some of the primes in the prime factorization of a*b to be applied in the expression of "a" and "b" as an expression of common primes to a non-negative power multiplied together respectively. if p^6 is part of the prime factorization of a*b then the p part of "a" is p^i and that of "b" must be p^(6-i) where the i can go from 0 to 6.
  • · Replies 35 ·
  • · Replies 38 ·
