Simple Node voltage method problem
The discussion focuses on applying the node voltage method to determine the voltage (v) in a given electrical circuit. The participant successfully calculated the node voltages v1 and v2 as 6 V and 18 V, respectively, using the equations v1 + (v1 - v2)/8 = 4.5 and (v2 - v1)/8 + (v2)/12 + (v2 - 30)/4 = 0. To find the voltage v across the 2-ohm and 12-ohm resistors, the participant is advised to use Ohm's Law to calculate the voltage drop across the resistors based on the known node voltages.
  • Understanding of the node voltage method in circuit analysis
  • Familiarity with Ohm's Law and voltage calculations
  • Basic knowledge of electrical circuit components such as resistors
  • Ability to solve simultaneous equations
  • Study advanced applications of the node voltage method in complex circuits
  • Learn how to analyze circuits with dependent sources
  • Explore the use of simulation tools like LTspice for circuit analysis
  • Investigate the impact of resistor values on voltage distribution in circuits
Electrical engineering students, circuit designers, and anyone looking to deepen their understanding of circuit analysis using the node voltage method.
DWill
Use the node voltage method to find v in the circuit shown.
(picture of circuit attached)
Solving for v1 and v2 I get:
v1 = 6 V
v2 = 18 V
I got the voltage at node 1 and 2 (along the top of the circuit), but I'm puzzled as to how to get v? Thanks for your help.
Can you see v is equal to the voltage across the 2 ohm resistor and the 12 ohm resistor?
You know the 12 ohms voltage, so find the voltage across the 2 ohms to find v.
v1 = 6 V
v2 = 18 V
You found the voltages at the two node points, so you know the difference between them. So you know the current in the 6 and 2 ohm resistors by Ohms Law. If you work out the voltage across one of them, and add it to the nearest node point, you can get the voltage there relative to the bottom rail.
