Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Other Sciences > Earth
Reply
image Formula for rate of evaporation of water Share It Thread Tools Search this Thread image
Old Aug23-09, 09:38 PM                  #1
deamon
deamon is Offline:
My sister and I are working on a project in which we need to know the rate of evaporation of water... I know that there are a lot of variables to this equation, but we aren't sure exactly where we will end up completing it, so does anyone know a formula to calculate the evaporation rate of water?
Also, if no one knows a good formula for it, I've come up with a list of variables which might possibly make a difference in the rate, but I'm not sure how much each matters. Can you tell me which of these actually makes a difference in the rate, and which ones don't affect it enough to worry about? The list we came up with was:
-heat (of the water)
-altitude (also air pressure)
-time
-speed of river/stream
-roughness of river bed (that would probably change the surface tension, causing a faster rate of evaporation)
-depth of water
-distance from equator (Water is a polar molecule, so would the magnetic fields of earth make a difference?)
-pollutants in water
-salinity
-mineral content (including heaviness of the minerals)
-humidity, and
-surface area
Thank you
Old Aug24-09, 02:29 AM                  #2
Andre
Andre's Avatar
Other Sci Guru 2008
Andre is Offline:
Recognitions:
PF Contributor PF Contributor
Re: Formula for rate of evaporation of water
A good start may be the Clausius Clapeyron relation
Old Aug24-09, 07:47 AM                  #3
jim mcnamara
jim mcnamara is Offline:
Recognitions:
Are you interested in evapotranspiration? There is also a hydrological component to stream water gain/loss.
image image
Reply
Tags
evaporation formula, evapration, rate of evaporation, water
Thread Tools
Similar Threads for: Formula for rate of evaporation of water
Thread Thread Starter Forum Replies Last Post
calculating Water evaporation rate Integral Materials & Chemical Engineering 9 Mar4-09 12:52 AM
Water Evaporation Rate nat558 Materials & Chemical Engineering 2 Feb18-09 10:03 PM
Evaporation of Water: Error in Formula? t3sseract General Engineering 3 Jul2-08 04:44 AM
Cyclohexanone Evaporation Rate Delgado, Maria General Physics 1 Nov4-06 04:32 PM
Cyclohexanone Evaporation Rate Delgado, Maria General Physics 1 May4-06 05:00 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
