I learned calculus I and II using stewart's. I also taught myself
  • Thread starter Thread starter physicsnoob93
    Calculus calculus i
The discussion revolves around the participant's desire to relearn calculus, specifically considering whether to start with Apostol's Volume 2. The conversation touches on the rigor of mathematical texts, the importance of understanding theory, and recommendations for additional resources.
  • One participant expresses dissatisfaction with their current understanding of calculus and seeks advice on starting Apostol Volume 2.
  • Another participant supports the idea of using Apostol's books but warns about the rigor and potential difficulty if the learner has not encountered such an approach before.
  • A different participant suggests that understanding proofs is essential and recommends Velleman's book for those unfamiliar with proofs.
  • This participant also advocates for Spivak's "Calculus" as a better starting point than Apostol Volume 2, arguing that it focuses more on theory rather than combining theory with learning calculus.
  • They further suggest that after mastering single-variable calculus, one could progress to real analysis with texts like Pugh's "Real Mathematical Analysis," emphasizing the need for a solid foundation before tackling multi-variable calculus.
  • Another participant notes that Spivak is a more cost-effective option compared to Apostol.
Participants express differing opinions on the appropriateness of starting with Apostol Volume 2. While some support it, others argue for a more foundational approach with Spivak or Apostol Volume 1 first. There is no consensus on the best path forward.
Participants highlight the importance of understanding proofs and the potential challenges of transitioning to more rigorous mathematical texts. The discussion reflects varying levels of comfort with mathematical rigor and the necessity of foundational knowledge before advancing.
physicsnoob93
I also taught myself vector calculus using Paul C. Matthew's book.
However, I'm not very satisfied and would like to relearn it proper. Is it a good idea to start on Apostol Volume 2?
Thanks
Sure, why not?
I like Apostol's books myself, so I must say, go for it! It is quite rigorous though, which could make it a shock to the system if you have never had such an approach from an earlier math text. For example, he uses set notation without apology or explanation (though he does explain it in Volume I). I don't think it's impossible to do if you have not had any similar rigor in an earlier course, but I would imagine it to be difficult--moreso without Volume I.
However, I think his books are easier to use if you've already learned the concepts of what he teaches--which you've done for the most part. It's not as hard learning the "whys" alone as learning the "whys" along with lots of new, difficult stuff at the same time! Note that the second edition of Volume II does cover some Linear Algebra, so there will be some new stuff to learn, though you can skip a fair chunk of it and do the multivariable calculus parts if you wish (then come back to the rest of the Linear Algebra afterwards, of course!).
I don't know if such a level of rigor is necessary for anyone outside of someone who has an interest in math, since I'm not out of high school myself, but it certainly can't hurt, and I at least find it fun to learn math that way. It also is certainly a good idea to start getting used to rigor if you plan on taking other courses which are loaded with it later!
Ok, so you know how to do calculus, now you need to learn the theory and understand its inner workings.
Do you know how to do proofs? If not, then check out Velleman's book:
https://www.amazon.com/dp/0521675995/?tag=pfamazon01-20
If you know how to do proofs, then I recommend Spivak's "Calculus". It only covers single-variable stuff, but you need to thoroughly understand single-variable before you do multi-variable, so I think jumping straight into Apostol vol.2 is a bad idea.
Why Spivak and not Apostol vol.1? Well, I think since you know how to do calculus, you need more theory rather than theory+learning to do calculus, and I think Spivak is more to the point on the theory.
After Spivak (or Apostol vol.1 if you like, they're both very good), you can move on to real analysis proper, from a book like baby Rudin "Principles of Mathematical Analysis", or even better I think, on to Pugh's "Real Mathematical Analysis". I don't think you should waste your time with Apostol vol.2, you need to learn other mathematics, you can't just be doing calculus all your life. Pugh would be a great next step after Spivak or Apostol vol.1, and it covers multi-variable calculus too. You'll need to learn linear algebra first for the multi-variable stuff though.
EDIT: I just checked amazon.com and Spivak is cheaper too :D
  • · Replies 17 ·
13K
  • · Replies 22 ·
