Register to reply
How to prove a topological space is metrizable
by variety
Tags: metrizable, prove, space, topological
Share this thread:
variety
#1
Aug28-09, 02:01 AM
P: 22
X is a set and P(X) is the discrete topology on X, meaning that P(X) consists of all subsets of X. I want to prove that X is metrizable.
2. Relevant equations
My text says that a topological space X is metrizable if it arises from a metric space. This seems a little unclear to me, which is probably why I am slightly confused.
3. The attempt at a solution
This problem seems really easy, I am just unsure of what I am supposed to prove. I want to show that X, together with the discrete topology, is metrizable. I choose the discrete metric d, which is defined by d(x,y) = 0 if x=y and d(x,y) = 1 if x=/=y.
This is where I am unsure of what I am supposed to show. I can start by showing that if we have the metric space (X,d), then every subset of X is open since all the points are isolated. Then P(X) satisfies the property of a topology on X, so (X,P(X)) is a topological space. But I don't think this is correct because we already assumed (X,P(X)) is a topological space. In fact, it is ALWAYS a topological space for any X, right?
Am I supposed to show that if (X,P(X)) is a topological space, (X,d) is a metric space? But this is also obvious because I already know that d is a metric.
What am I supposed to be proving?
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
Dick
#2
Aug28-09, 08:42 AM
Sci Advisor
HW Helper
Thanks
P: 25,243
You start with a space with the discrete topology. You want to find a metric that induces the discrete topology. You already did that with the discrete metric (did you show it's a metric?) and you showed it induced the discrete topology which you did when you said "I can start by showing that if we have the metric space (X,d), then every subset of X is open since all the points are isolated." I'll admit it's not a hard proof, but it's not completely without substance.
im_xyz
#3
Sep26-10, 05:23 AM
P: 1
counter example of topological space which is not metric space
radou
#4
Sep26-10, 05:30 AM
HW Helper
radou's Avatar
P: 3,224
Quote Quote by variety View Post
Given any set X, (X, P(X)) is a topological space, this is a fact, and your starting assumption.
Of course you know that d is a metric. You found a metric which induces the discrete topology. As Dick noted, there's not much more to it.
Register to reply
Related Discussions
RP^n as a topological space Differential Geometry 4
Open subspace of a compact space topological space General Math 1
Metric space versus Topological space Calculus 5
Topological space help Calculus & Beyond Homework 21
Open set in a topological space Calculus & Beyond Homework 4
