Unexpected Peaks in XRD: Causes Besides Doping?
  • Context: Graduate
  • Thread starter Thread starter drizzle
The discussion revolves around the unexpected peaks observed in X-ray diffraction (XRD) patterns of a pure metal oxide compound. Participants explore potential causes for these peaks beyond doping, including structural and synthesis-related factors.
  • One participant questions the definition of "pure material," suggesting that the presence of superlattices or multiple lattice structures could lead to additional peaks.
  • Another participant notes that vacancies and defects in the crystal structure might also contribute to unexpected peaks.
  • A participant mentions that the synthesis method could introduce defects, potentially causing the observed peaks.
  • One response proposes that incomplete reactions of starting materials during synthesis might result in additional peaks in the XRD pattern.
  • Another participant suggests that a small amount of impurity, which is a strong X-ray scatterer, could explain the large peaks observed, emphasizing that peak height is relative to the scattering power of the materials involved.
Participants express various hypotheses regarding the causes of unexpected peaks, indicating that multiple competing views remain. There is no consensus on a single explanation for the phenomenon.
Participants highlight the importance of clarifying what constitutes a "pure material" and the potential influence of synthesis methods and impurities on the XRD results. The discussion remains open-ended regarding the exact causes of the observed peaks.
Researchers and practitioners in materials science, solid-state physics, and analytical chemistry may find this discussion relevant, particularly those interested in XRD analysis and the characterization of metal oxides.
drizzle
what possible explanation to an unexpected peak that may appear in an XRD pattern of a pure material [not doped, as far as I know the extra peaks that may occur would be due to the dopants], what causes, other than doping, could show alien peaks in a pure compound? thanks in advance
You need to explain what you mean by a "pure material". Is this a single-crystal throughout, or do you just require that it is made up of only one type of material that you say, is undoped?
If the material has something called a "superlattice", then that will show up as an extra peak. If it is made up of only one type of atoms, but it can have two or more different lattice structures, that that will show up as additional peaks. Vacancies and defects will also do the same. Etc... etc.
Zz.
thanks for replying ZapperZ, it's a metal oxide compound [in a powder form], this material has a number of knowable peaks each at a certain (hkl) plane [recorded in JPDS cards], however, a number of extra peaks show in the XRD pattern [none of them matches with the known peaks of this material], I thought of defects as a possible candidate, but it doesn’t sound reasonable, cause those peaks aren’t small ones [a number of them have high intensities], I could be wrong though...is the synthesis method of this material a possible cause to those peaks? [I mean to form defects in the material which in turn lead to those peaks]
If your starting materials used to create your compound didn't react completely, you will see peaks from them. Have you checked for those?
The simplest explanation is that there is a small amount of impurity, but it is a strong x-ray scatterer so there are large peaks in the measured spectrum.
Remember that the peak height only indicates the relative mass fraction if the scattering power of the compounds being compared are the same.
If you put a small amount of transition metal in graphite you'll primarily see the metal peaks.
  • · Replies 0 ·
  • · Replies 30 ·
  • · Replies 0 ·
