Maxwell's Equations: Static or Dynamic Fields?
  • Thread starter Thread starter Amith2006
    Maxwell's equations
The discussion revolves around the nature of electric and magnetic fields as described by Maxwell's equations, specifically focusing on whether fields produced by time-varying magnetic fields are static or dynamic. The original poster seeks clarification on the implications of Faraday's law of electromagnetic induction in this context.
  • Participants explore the definitions of static versus dynamic fields, questioning whether a time-varying magnetic field can produce a static electric field. Some discuss the implications of changing assumptions about the nature of the fields involved.
The conversation includes various interpretations of how time-varying magnetic fields relate to electric fields. Some participants suggest that induced electric fields cannot be truly static, while others propose scenarios involving uniform motion of magnets and coils to explore the conditions under which static fields might be produced. There is no explicit consensus, but productive lines of inquiry are evident.
Participants note that the behavior of magnetic fields and their spatial uniformity affects the nature of the induced electric fields. The discussion also touches on practical limitations in generating static fields through time-varying sources.
Amith2006
# Everyone knows that a time varying magnetic field produces an electric field and vice versa. But are the fields produced, static or dynamic? From Maxwell's equations(Faradays and Ampere's law), it seems like they are static. Moreover, Faraday's law of electromagnetic induction doesn't say about production of a time varying electric field due to a change in magnetic flux. Could someone please clarify this concept?
# If a time varying magnetic field can produce an electric field, then it can certainly exert a force on a charge at rest, right?
As I understand the term, "static" means "no explicit time dependence" in the fields. Maxwell's equations become
[tex]\nabla \cdot D = \rho[/tex]
[tex]\nabla \cdot B = 0[/tex]
[tex]\nabla \times E = 0[/tex]
[tex]\nabla \times H = J[/tex]
These equations have no time-varying fields and the fields are static. If you change your mind and say " I want a time-varying magnetic field to create an electric field", then you are saying that the fields are no longer static. Once you do that, you cannot turn around and ask if they are static because you have already assumed that they are not.
If by "it" you mean the electric field, the answer is yes. That's how induced currents move around.
So, a time varying magnetic field produces a static electric field which is evident from
[tex]\nabla[/tex] [tex]\times[/tex] [tex]\textit{E}[/tex] = -dB/dt {Faradays law}
isn't it?
isn't it?
An electric field produced this way need not be 'static'. In fact, in order for it to be static, you would require the magnetic field to be linear in time (i.e. [itex]B=\alpha t+ \beta[/itex]), and in practice, it's impossible to produce such a field since its magnitude would increase without bound as time goes on. You can always produce an induced electric field that is static for a short period of time, but you can never actually induce a truly static electric field in this manner.
Thats a more precise answer.Thanx. Suppose u have a coil and magnet. If the magnet is moved with uniform velocity, can we produce a static electric field?
No, because the magnetic field of a magnet is not spatially uniform which means that equal displacements of the magnet do not result in equal changes of the magnetic field.
The easiest way to produce a quasi-static Faraday field is probably to take two large Helmholtz coils (the B-field in between will be almost uniform) and linearly ramp up the current in the coils during some time interval (you can only do this for a limited time of course before the power needed to continue becomes prohibitively large). If you were to place a small circuit with a voltmeter in between the two coils, you should measure a constant voltage during that time interval (since the induced field is quasi-static, the voltage in the circuit will be aswell).
