The Doppler Effect of radar gun
The problem involves the Doppler Effect as it relates to radar guns used for measuring the speed of a car moving away from a stationary emitter. The radar gun emits microwaves at a specified frequency, and the task is to determine the speed of the car based on the frequency difference detected.
  • The original poster attempts to understand the roles of the radar gun and the car in the context of the Doppler Effect, questioning whether to treat the car as the receiver or emitter. Some participants suggest clarifying the stationary nature of the radar gun and the movement of the car.
Participants are exploring the implications of the radar gun's stationary position and the car's movement. Some guidance has been offered regarding the nature of the signals and the roles of the emitter and receiver, but there is no explicit consensus on the correct approach to the problem.
There is a noted discrepancy in the speed of wave propagation used by the original poster compared to the actual speed of microwaves. This raises questions about the assumptions made in the calculations.
Outc4sted
You are in charge of calibrating the radar guns for a local police department. One such device emits microwaves at a frequency of 2.15 GHz. During the trials, these waves are reflected from a car moving directly away from the stationary emitter. You detect a frequency difference (between the received microwaves and the ones sent out) of 291 Hz. Find the speed of the car and give the answer in km/h.
One thing that I kind of don't understand, is that the radar gun is both the emitter and receiver, and the guy is stationary. So I just assumed that you would treat the car as the receiver. I even attempted to treat the car as the emitter and the guy as the receiver thinking of after the microwaves hit the car, but that gave the same answer.
(2.15 * 10^9 ) - 291 = ( (343 - v)/(343) ) * (2.15 * 10^9 )
v = 4.6425 * 10^-5 m/s
v * 3.6 = 1.6 * 10^-4 km/h
Radar guns use microwaves, not sound, and they travel at 300 million meters per second. Much faster than the 343 m/s you were using.
Think it through. The gun is stationary. The car is moving.
Also, there are two sources of redshift:
(1) The radar gun's microwaves hit the car, which perceives them to be redshifted Here, the radar gun is the emitter and the car is the receiver.
(2) The car reflects the microwaves back at the frequency it believes them to be at. Since the gun is moving away, the microwaves are redshifted a second time. Here, the car is the emitter and the car is the receiver.
