Refraction Index: Does Temperature Change It?
  • Context: High School
  • Thread starter Thread starter darkar
    Index Refraction
The discussion centers on whether the refractive index of water or other materials changes with temperature, and the factors influencing the speed of light in different media, particularly comparing air to a vacuum.
  • Exploratory, Technical explanation, Conceptual clarification
  • Some participants propose that the refractive index changes with temperature for most materials.
  • One participant mentions that the refractive index can also be affected by stress and electric fields.
  • Another participant explains that while light travels at "c" in a vacuum, its speed appears slower in matter due to the processes of absorption and re-emission.
  • A participant illustrates the temperature effect on refractive index by referencing the visual phenomenon of heat waves seen near buildings.
  • It is noted that heating or cooling a material changes its density, which in turn affects the refractive index.
Participants generally agree that temperature affects the refractive index, but the discussion includes various factors and explanations without reaching a consensus on all aspects.
Some assumptions about the relationship between temperature, density, and refractive index are present, but not all participants elaborate on these connections in detail.
darkar
Hello,
will refreactoin index of water or any material will change its refreaction index when temperature changes? What make the speed of light slower in air compare to vacum.
Science news on Phys.org
Refractive index changes with temperature for most materials. It can also be changed by stress and electric fields.
Light always travels at "c", but when traveling through matter, it will be absorbed and re-emitted many times. Each absorption and re-emission takes a small amount of time.
Njorl
the dude is right!
You can see the temperature effect by looking at the edge of a bulding. The "heat waves" you see are caused by the index of refraction changing from the heat escaping the building.
By heating/cooling a material the density will change. Which will inturn change the index of refraction.
  • · Replies 33 ·
