What Is the Magnitude of the Electric Field Acting on a Charged Mass?
The problem involves a ball with a specified mass and charge suspended in a uniform electric field, with the angle of suspension provided. The objective is to determine the magnitude of the electric field acting on the ball.
  • Participants discuss the conversion of mass to kilograms and the calculation of forces involved. There are questions about the direction of the electric field and its relevance to the problem. Some suggest using a free body diagram and trigonometric relationships to find the horizontal force vector.
The discussion is ongoing, with various approaches being explored. Some participants have provided guidance on using trigonometry and the relationship between force and electric field, while others are questioning assumptions about the direction of the electric field.
There are indications of confusion regarding the correct gravitational constant to use and the assumptions about the electric field's direction. Participants are encouraged to clarify these points to progress in their calculations.
lala78
a ball with a mass of 0.450 g and positive charge of q=31.1 μC is suspended on a string of negligible mass in a uniform electric field. We observe that the ball hangs at an angle of θ=19.0o from the vertical. What is the magnitude of the electric field?
Force of y component=massxGravity
x component= Force of y component Tan angle
converted mass to kg.
F= .00045 X 6.67E-11= 3.00015E-14
3.00015E-14 Tan 19= 1.034E-14
convert to Coulombs.
1.034E-14/3.11E-5
=3.32E-10
but answer in incorrect any suggestions what I am doing wrong?
I tried doing it without converting to kg and got the answer 3.32E-7 and that was wrong as well.
what's the direction of electric field?
I don't think that's relevant here.
First, draw a free body diagram. Then calculate the force in the vertical direction. Now, that you know an angle and a force vector, you can calculate the other force vector (in the horizontal direction) using trig. Then, use the equation F = Eq; You know F, and you know q, solve for E.
There you've assumed that the electric field is HORIZONTAL, so you've given its direction without knowing it as data (i can guess that's what the problem posted by lala78 means but we just can't be sure until lala checks and confirms it).
lala78 said:
1.
This step is wrong.
F = m*g, where g = 9.8 m/s^2
  • · Replies 17 ·
  • · Replies 23 ·
