Thread Closed
about Separation of Variables for the Laplace Equation
Share Thread Thread Tools
Sep7-09, 11:06 PM   #1
This is a try for the solution of Laplace Equation. We have to calculate the potential distribution in a cylinder coordinate. However, there is a step really bring us trouble. Please go to the detail. You can either read it in the related URL, or in my PDF attachment..
The uncompleted solution is:
http://i1021.photobucket.com/albums/.../Bessel001.jpg
2. Relevant equations
The method on the book is that:
http://i1021.photobucket.com/albums/.../Bessel002.jpg
3. The attempt at a solution
I really do not know what the basis of above equation is. Why can we get (2) from (1)? Does anyone give me any advice?
Thanks in advance.
Regards
Hector
File Type: pdf This is a try for the solution of Laplace Equation.pdf (44.6 KB, 1 views)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Sep8-09, 01:22 AM   #2
Recognitions:
Homework Helper Homework Help
You do exactly what they say you should do:
[tex]U_0=\sum_{m=0}^{\infty}A_m\sinh\left(\frac{P_m h}{a}\right)J_0\left(\frac{P_m r}{a}\right)[/tex]
[tex]\implies\int_0^a U_0 J_0\left(\frac{P_n r}{a}\right)rdr=\int_0^a \left[\sum_{m=0}^{\infty}A_m\sinh\left(\frac{P_m h}{a}\right)J_0\left(\frac{P_m r}{a}\right)\right] J_0\left(\frac{P_n r}{a}\right)rdr=\sum_{m=0}^{\infty}A_m\sinh\left(\frac{P_m h}{a}\right)\left[\int_0^aJ_0\left(\frac{P_m r}{a}\right) J_0\left(\frac{P_n r}{a}\right)rdr\right][/tex]
What does the orthoganality condition tell you about the integral on the RHS?
Sep8-09, 01:57 AM   #3
Wo, Thanks for your reply so soon!
I understood your means.
About the orthogonality condition, actually, there is one of the charactrestics of Bessel function, isn't it?
we have:
[tex]\int _0^{\alpha }J_0\left(\frac{P_mr}{\alpha }\right)J_0\left(\frac{P_nr}{\alpha }\right)rdr=0[/tex] if [tex]m\neq n[/tex]
where [tex]P_m[/tex] is the solution of Bessel Function [tex]J_0(x)=0[/tex]
Regards
Hector
Sep8-09, 02:22 AM   #4
Recognitions:
Right, so the only non-zero term in the sum
[tex]\sum_{m=0}^{\infty}A_m\sinh\left(\frac{P_m h}{a}\right)\left[\int_0^aJ_0\left(\frac{P_m r}{a}\right) J_0\left(\frac{P_n r}{a}\right)rdr\right][/tex]
will be the [itex]m=n[/itex] term.
[tex]\implies\int_0^a U_0 J_0\left(\frac{P_m r}{a}\right)rdr=A_m\sinh\left(\frac{P_m h}{a}\right)\int_0^a\left[J_0\left(\frac{P_m r}{a}\right)\right]^2 rdr[/tex]
Thread Closed
Thread Tools
Similar Threads for: about Separation of Variables for the Laplace Equation
Thread Forum Replies
Partial Differential Equation using separation of variables Calculus & Beyond Homework 1
Differential Equation- Separation of Variables Calculus & Beyond Homework 4
Laplace Cylindrical Coordinates (Separation of variables) Differential Equations 2
Paritial Differential Equation separation of variables Calculus & Beyond Homework 8
diffusion equation & separation of variables Calculus & Beyond Homework 3
