Get Quick Math Help: Solving x^3 + (2x10^5)x^2 + 250x - (5.08x10^-3) = 0 for x
  • Thread starter Thread starter muaddib7
    Homework
The discussion revolves around solving a cubic equation of the form x^3 + (2x10^5)x^2 + 250x - (5.08x10^-3) = 0 for the variable x. Participants express the need for guidance on how to approach the problem rather than seeking the final answer.
  • Participants discuss various methods for solving cubic equations, including factoring and the use of the quadratic formula, which is noted as inappropriate for this context. Some suggest using numerical methods, while others reference historical formulas for cubic solutions.
The conversation is ongoing, with participants exploring different methods and questioning the applicability of certain techniques. There is a recognition that the equation is complex and may not yield to straightforward rational root checking.
Some participants highlight the requirement for the solution to be a real number and mention the potential complications associated with analytic methods for cubic equations.
muaddib7
Need to solve the following equation for x
I've tried factoring, and quickly found the quadratic formula to be a dead end. Answer has to be a real number. I just need to know how to do it, not necessarily the answer. Thanks all!
Inasmuch as your equation is a cubic (third-degree polynomial), the quadratic formula doesn't apply. It can be used only on quadratic (second-degree) equations. IOW, equations of the form ax2 + bx + c = 0
There is a formula that can be used to solve cubic equations, that was developed sometime in the 14th century or so by an Italian mathematician. I don't remember the name of the algorithm, but if you searched Wikipedia you might be able to find it.
Use a numerical method to find the root, please? The root is very likely not rational and the analytic method will paralyze you with complications, all grace to Cardano. Try bisection first. You can do it on a calculator.
  • · Replies 24 ·
