Projectile motion and acceleration HELP
The problem involves a lemming that accelerates uniformly from rest before jumping horizontally off a 20 m high cliff, with the goal of clearing 4 m of rocks at the base. Participants are exploring the relationship between horizontal and vertical motion in projectile motion, particularly how initial conditions affect the calculations.
  • Mixed
  • Participants discuss the implications of the lemming's initial horizontal velocity and how it relates to free fall. There are questions about the role of the initial 2 meters in determining horizontal velocity and whether acceleration can exist in the horizontal direction. Some participants calculate time to fall and horizontal velocity, while others explore the use of different acceleration values for vertical motion.
Some participants have provided calculations and interpretations regarding the time of flight and necessary horizontal velocity. There is an ongoing exploration of when to apply gravitational acceleration and how to separate the components of motion. The discussion reflects a mix of understanding and confusion about the concepts involved.
Participants are navigating assumptions about initial conditions, the nature of horizontal motion, and the effects of gravity on vertical motion. There is a mention of using different values for gravitational acceleration, indicating a potential source of confusion.
nrw
A lemming accelerates uniformly starting from rest 2 meters before jumping horizontally from the top of a 20 m high cliff. What is the minimum acceleration required so that the lemming can clear the rocks stretching out 4 m from the base of the cliff?
I know that we have both an X and Y component we need to calculate, but what is confusing to me is that - how does the 2 meters at the beginning play into the horizontal velocity? And since the lemming is jumping horizontally - what does that mean? Does that mean something other than free fall? Is the initial velocity of the jump the final velocity of the horizontal velocity?
I have tried this several ways, but have no idea if I'm doing it right. For the X component, I have the initial velocity is 0, the final velocity is unknown, the displacement is 2 m (??) and acceleration is 0 (because can acceleration exist in a horizontal dimension?) and the t is unknown. For the y component, I have the initial velocity as 0, but I don't know if this is correct? The acceleration is -10 m/s2, the Y displacement is -40. So, do I use the pythagorean theorem to find the final velocity of Y? I'm totally confused about where to start. Thanks!
Welcome to PF!
Hi nrw! Welcome to PF! :smile:
Let's restate the problem more clearly …
i] a projectile leaves the top of a 20m cliff, with initial velocity purely horizontal, and lands 4m from the base: what is its initial speed, v0?
ii] what acceleration must it have had to get from rest to v0 after 2m?
Thanks! So when the initial velocity is purely horizontal, that means that we are assuming the initial speed of the fall is 0 and thus, the y-component is calculated using simple free fall acceleration?
I first calculated the time it would take the lemming to land if it were free falling... using y=Vi (t) - 1/2 a t2. This gives me 2 seconds. Then, if the lemming has only 2 seconds to clear 4 m, it must have a velocity of 2 m/s2 (using x=vt). Then, to calculate the acceleration, I use v2 = vi2 + 2aX and get the acceleration of 1 m/s.
Does that sound right?
I guess I'm confused about when to use a = -9.8 (all falls?) and when to break a equation up into both X and Y components.
Thanks!
Yup! :biggrin:
Using g = 10, yes. :smile:
Don't ask yourself "what is the acceleration?" …
ask yourself "what is the force?"
If it's gravity, then it's 9.8 (or 10 :wink:) …
if it's an applied force, then it isn't 9.8 !
(of course, sometimes it's both … eg a rocket)
But you must always break it up into X and Y components (or surface and normal, or whatever) …
F = ma is a vector equation, and you must treat it as such (unless of course the motion is obviously one-dimensional, in which case one of the component equations will be 0 = 0 :wink:)
Wow! Thank you so much for your help! Thinking of acceleration as force really helps - I appreciate your time and the way you ex;lain things!
  • · Replies 21 ·
