Can toothpicks and wood glue mimic real bridge designs for a school project?
  • Thread starter Thread starter technoweasel
    Bridge Design
This discussion centers on designing a bridge using toothpicks and wood glue for a school project, specifically addressing whether real bridge designs can be applied. Participants confirm that an arch structure is optimal for a point load applied at the center, while also noting that an inverted V shape can be effective. The conversation emphasizes that the bridge form should reflect the bending moment diagram, with a pyramid shape for point forces and an arch for distributed forces. The consensus is that understanding the application of forces is crucial for effective design.
  • Basic understanding of bridge design principles
  • Familiarity with bending moment diagrams
  • Knowledge of geometric shapes such as arches and pyramids
  • Introduction to physics concepts related to forces and load distribution
  • Research the principles of bending moment diagrams in structural engineering
  • Explore the mechanics of arch bridges and their advantages in load distribution
  • Study the properties of materials like toothpicks and wood glue in model building
  • Investigate online resources that detail bridge design and construction techniques
This discussion is beneficial for students in engineering or physics, educators teaching bridge design concepts, and hobbyists interested in model building and structural integrity.
technoweasel
I have a question about bridges. I am not sure if this is the right place, since everyone else is discussing more advanced things, but I couldn't find anything (I did try to search). If this post is out of place just please redirect me.
For school I need to design and then build a bridge to connect 2 supports that are about a foot apart, using only toothpicks and wood glue. My question is this: Would designs for real bridges work in this situation, even though the force will only be applied to a point in the center of the structure? I have read a bit about the parabola and catenary in calculus books, but would a curve be best in this situation? If a cable supporting a uniform weight (along the x axis) makes a parabola, and it can be inverted to create an arch with the forces reversed, then can a cable supporting a single weight that pulls it down in a V shape be reversed to make an optimal arch for this application?
What is wrong with my reasoning? I haven't been through physics in school yet, so I might not even be asking the right questions. Please help me by explaining what is going on or redirecting me to some good online resource.
Yes, real bridges would work in this situation. An arch would perhaps be optimal, but an inverted V would work well, also. Your reasoning sounds correct.
The ''best'' curve depends on that how force is applied to the bridge. The bridge form should mirror bending moment diagram. For point force in middle it would be shape of a pyramid, for distributed force it is an arch.
Makes sense. I currently agree with the post by archis now, which matches the concept posted by technoweasel. And by the way, technoweasel, it doesn't really matter if the V is upright (below the bridge) or inverted.
You're right, nvn.
Thanks, guys. If I wasn't clear, the "bridges" do not require a road deck, and the instructor adds weights to an area near the center of the span until the structure collapses. Are there any web pages that discuss this in detail? I might use a curve anyway because I have to do a report and it would be much more interesting to write about curves and their derivation. However, I guess I could write about the caterary and parabola and why I decided NOT to use them. I will continue researching.
  • · Replies 17 ·
