Maximizing Train Speed with a Damped Buffer Stop: Impulse-Momentum Approach
  • Thread starter Thread starter izzyosman
The discussion focuses on calculating the maximum speed at which a train of mass 100 Mg can collide with a damped buffer stop without exceeding a final speed of 1.5 m/s after a 2.3 m travel distance. The resisting force is modeled as cxdot, where c equals 200 kN/m·s. The solution involves applying impulse-momentum equations and integrating the damping force over time to derive the initial velocity of the train. The final equations simplify to allow for the determination of the train's initial speed without additional unknowns.
  • Understanding of impulse-momentum principles in physics
  • Familiarity with damping forces and their mathematical representation
  • Knowledge of integration techniques in calculus
  • Basic concepts of kinematics related to motion and forces
  • Study the application of impulse-momentum equations in collision scenarios
  • Learn about damping forces and their effects on motion in mechanical systems
  • Explore integration techniques for solving differential equations in physics
  • Investigate the principles of kinematics in relation to real-world applications
Students in physics and engineering, particularly those focusing on dynamics and mechanical systems, as well as professionals involved in railway engineering and safety design.
izzyosman
A buffer stop at the end of a railway track has a moving part of mass, 2 Mg, which can move 2.3m parallel to the track. The force resisting the motion of the moving part is given by cxdot where xdot is the velocity and c is 200kn/m s
What is the greatest speed with which a train, of mass 100 Mg, can hit the buffer stop if, at the end of its 2.3m travel is not to exceed 1.5m/s?
Assume that after impact, the train and the moving part of the buffer stop move together.
I started with the impulse momentum equations
Train: -F t = 100x10^3 (1.5-x) where x is the initial velocity of the train
Buffer: (F-cxdot) t = 2x10^3 (1.5-0)
I do not know how to proceed because I have not seen an impulse momentum equation which includes a damper. Please help!
I've come to the conclusion that the x and xdot are the same thing as the damping force does not apply until after impact. However I also notice that i only have 2 equations and 3 unknowns: xdot, t and F, and so I'm unable to continue, can anyone think of another equation I'm missing?
Never mind people I got it!
Okay so what i did was start off with the integral form because the damping force changes over time:
Train: -Ft = 100 (1.5 - xdot)
Buffer: Int(F-cxdot) dt = 2(1.5-0) note that the two xdots are not necessarily the same as it changes over time.
The buffer eqn can reduce to Ft - c Int(xdot)dt = 2(1.5)
Since Int(xdot)dt = 2.3m, I now only have the initial velocity of the train, xdot, to deal with, and everything cancels out!
Yay me! :D
  • · Replies 19 ·
  • · Replies 24 ·
