Solve Square Root Method: (x-1)^2 = 4
The problem involves solving the equation (x - 1)^2 = 4, which falls under the topic of algebra, specifically dealing with quadratic equations and the square root method.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods to approach the equation, including expanding the squared term and applying the square root directly. Some question the validity of certain steps, such as the expansion of (x - 1)^2.
Several participants have shared their attempts at solving the equation, with some suggesting different methods and checking the results. There is a mix of interpretations regarding the steps taken, and while some results are presented, there is no explicit consensus on the best approach.
Some participants highlight the importance of considering both positive and negative roots when applying the square root method, and there are discussions about the implications of initial assumptions in the problem setup.
elflacodepr
(x - 1)^2 = 4
This is what I've done
(x - 1)^2 = 4
Everything inside parenthesis goes to: ^2
x^2 - 1^2 = 4
now we got
x^2 - 1 = 4
Now (I think) I use the square root method
x^2 - 1 = √4
x^2 - 1 = 2
Now I factorize:
(x - 1) (x +1) = 2
This is what I've done for now, shall I make √ on both sides in this equation x^2 - 1 = √4?
(x-1)2≠x2-1
(a+b)2=a2+b2+2ab
you can also take the square root initially and check the two cases
X2=A => X=±√A i.e. X= +√A or X=-√A
Thanks, All I did now is use the square root right on start:
√(x - 1)^2 = √4
So now we go this:
x - 1 = ±2
which gives me the following results:
x - 1 = ±2
x = 2 + 1
x = 3
OR
x - 1 = ±2
x = -2 + 1
x = -1
√(x - 1)^2 = √4
So now we go this:
x - 1 = ±2
x - 1 = ±2
x = 2 + 1
x = 3
OR
x - 1 = ±2
x = -2 + 1
x = -1
Good. This is correct because if we put x=3 or x=-1 into (x-1)2, we ill get '4'.
Thanks!
  • · Replies 21 ·
